2007-2008 Fx2 rear one inch block part number?
Hah! Funny story there, Diggman... I initially had a shop install the AS spacers. I am certain that I ordered the 2" kit from Autospring. I then decided I wanted another .5" of lift to run the 305/70R17s that I have on now. So.... I ordered the 2.5" kit and had the shop install those.
As it ends up, I had the 2.5" spacers on all of the time... apparently AS sent me the 2.5" kit instead of the 2" kit initially. Paid $200 in labor for that screw-up!
Hence the extra 2.5" AS kit.
Will
Will
Im interested in the 1" block also, I just put a home made add-a-leaf on my truck yesterday (FX4) which raised the rear ~1.5". I'd like to bring it back down close to where it was stock, since with my 2.5" daystar it sat perfectly level. I haul a lot of crap with this truck and needed to get rid of the saggy-but syndrome every time I loaded it, but I didn't want to raise it very much. Bags would have been better, but this is cheaper. Part number anyone? extra set laying around?
When I was 2/4 droped I had dual eye-let air shocks and those were very nice, I drove around normal with them about 40-60psi and when I loaded a 600lb fourwheeler I put about 120psi and it drove great n didnt sit on the bump stops, If you hit a big bump then of corse it will hit alittle... If ur'll interested Ill take a look tomorrow when I go to my shop to see what part number they are from Bennit auto supply... I paid under 100 but you should be able to get them for about 160 for both plus the air lines
