started to tint tails, not working for me.
Old Apr 17, 2008 | 12:10 AM
City of Champs's Avatar
so I followed various instruction on threads about tails on this site and others. I first wet sanded out the clear on the oem tails w/ 1500 grit, dish soap and water. I put a light layer of VHT Nightshades in the paint booth at work but its turned out kinda spotty / orange peal..... just not perfect.
no biggie right, so i lightly wet sanded again with 1500 but basically took it all off before happy. I have done like 3 coats not and I have never liked how a coat came out. Did a get a bad can on Nightshades?
do you guys just leave it looking all spotty till the end and the clear takes care of it?
Should i just buy a different can? and yes I followed instructions as far as shaking, spray distance, and cleaning the tip after use to keep clean and useful.
Thanks guys
Old Apr 17, 2008 | 12:13 AM
Budha05STX's Avatar
Just a wild random thought.....how about the temp range listed on the can? Sometimes it can't be too hot or too cold.
Good luck with it.
Old Apr 17, 2008 | 12:21 AM
never thought of that but the booth was more of a dust free zone, it wasnt in use when i was in their playing.... they keep it at room temp or a tick warmer when its not baking anything
Old Apr 17, 2008 | 12:34 AM
you can always return it and try another one
Old Apr 17, 2008 | 12:44 AM
Copenhagen848's Avatar
If that doesn't work you can always go with Harley tails for $57.
Old Apr 17, 2008 | 12:53 PM
Myren's Avatar
So did you build up the coats or sand after each one?
Old Apr 17, 2008 | 01:05 PM
ATOM's Avatar
when i did my last set, i just sprayed them til they were dark enough for me and them wet sand them. and then did it again and again, make sure you shake the **** outta that can otherwise you'll get fisheyes, well i did anyway. i just scotch brited them to begin with though.
Old Apr 17, 2008 | 10:01 PM
ya i wet sanded btw every coat. Should I just do my four coats to get the desired effect then sand?
Old Apr 17, 2008 | 10:11 PM
K1NGoftheRanch's Avatar
when i did mine i just sanded in the beginning...then wetsanded after 4 coats with 2000
Old Apr 17, 2008 | 10:21 PM
TonkaTruck33's Avatar
dont know if this would help a little..
https://www.f150online.com/forums/sh...d.php?t=324418
Old Apr 17, 2008 | 10:30 PM
ok i guess ill start over, do my 4 coats then sand.
Old Apr 18, 2008 | 12:31 PM
Myren's Avatar
That's what you should do. I sanded, put on enough coats till they were dark enough and let them set up, very lightly sanded, sprayed 3 coats of clear. I need to polish though........ But yeah, don't sand after every coat. Good luck!
