Quieting the Scab doors
Old Apr 10, 2008 | 06:30 AM
n8er00's Avatar
Has anyone come across a way to eliminate the "looseness" of the rear Scab doors. Every time i hit a bump, it sounds as though my doors aren't closed tight b/c the seem to shake (or at least thats what it sounds like). And yes, i've made sure that they are fully latched both top and bottom. Is there any sort of adjustment that can be done to tighten em up possibly?
Old Apr 10, 2008 | 08:20 AM
Big Slick's Avatar
mine does the same thing. i haven't taken the door panels off to check for anything loose, but i am going to apply sound deadener to them when i replace the speakers.
Old Apr 10, 2008 | 08:29 AM
luke280's Avatar
They will do this if they arn't ''fully'' closed all the way. Try really slaming them then see if you hear the noise. Now I don't mean rare back and smash teh door into the jam, but forcefuly shut it. It worked on mine and haven't had an issue for years.
Old Apr 10, 2008 | 09:08 AM
JMBdevotee's Avatar
+1 to Luke
I notice it when the rear door is not solidly closed. It happened a few time and since then I have just given the doors a solid shut (not slam) and it has not happened anymore.
Old Apr 10, 2008 | 09:32 AM
n8er00's Avatar
I've tried the slamming technique and doesn't seem to work and I've checked the inside and there's nothing loose. This may be a stretch, but I was wondering if there was an ability to adjust the D-rings around the door frame that the latch attaches. Possibly moving it in just a very small amount may hold the door tighter against the truck when closed? Or, wrap the D-rings with something to create a tighter fit. Again, may be a stretch but has crossed my mind. What do you guys think?
Old Apr 10, 2008 | 11:03 AM
COLORADO_CAMPER's Avatar
n8er00,
Do take another look at whether your rear door is fully latching at the top. Push the door closed firmly with your hand toward the top then see if the door wiggles at all when you pull on it. The top latch is very finicky and the door will bang around like mad if it doesn't latch completely. I had this problem myself and it drove me nuts for a couple months beofre I finally realized that the rear doors weren't always latching at the top - even when I slammed them (don't do this by the way because it won't accomplish anything. The door will just bounce back and still not latch completely. You have to close it firmly with your hand toward the top latch).
Hope that helps.
Oh, and I also has another annoying rattle that I finally traced to my bed cap - it was installed just a wee bit too close to the cab and it would touch ever so slightly over bumps.
Old Apr 10, 2008 | 11:17 AM
n8er00's Avatar
I'll definitely check on that top latch tonight on my way home.
Old Apr 10, 2008 | 11:49 AM
attworth's Avatar
I agree with the doors not being closed all the way. On my rcab, if I don't shut the little doors I get a lot of noise. Even though when I shut the driver/passenger door, the back doors aren't fully closed.
Old Apr 10, 2008 | 11:51 AM
n8er00's Avatar
will you hear a legitimate "click" if the door isn't closed and you push in on the top?
Old Apr 10, 2008 | 11:54 AM
attworth's Avatar
Very faintly. I liken it to closing the tailgate. The gates on these trucks are so light, you almost feel like you have to barely close it. When you do so, it gives a light "click" and feels secure. Yet I've had people tell me it bounces around all over the place (in-out.) Now, with a forceful close, it doesn't do that.
Old Apr 10, 2008 | 12:05 PM
n8er00's Avatar
great hopefully it works. ill give it a shot tonight. thanks guys
Old Apr 10, 2008 | 12:32 PM
Ftruck05's Avatar
I have found this to be quite annoying. Everytime I shut my rear doors I give them a wiggle. If it is not latched there will be 1/4"-1/2" of play. It's just something I learned to deal with though, not really worth complaining about.
Old Apr 10, 2008 | 01:14 PM
TonkaTruck33's Avatar
guys i found the solution for this problem...
i got some black electrical tape, wraped a little bit around the d rings maybe twice or 3 times. close the door, and ur done. it worked for me. it dont look bad ether. just make sure u wrap it around tight!
Old Apr 10, 2008 | 01:19 PM
luke280's Avatar
Umnmnmm.... I will have to disagree with that statement. Take the gate off and you will see how light they are.
Sorry for the hi-jack. Back to your regulary scheduled topic.
Old Apr 10, 2008 | 01:23 PM
keith61760's Avatar
Going to try that. My rear doors always make noise like they aren't properly latched. Everytime I close them I grab the top part to make sure they did lat6ch and I still get rattles like its not latched.
