Hello Everyone
Old Apr 9, 2008 | 05:16 PM
You open a pic in your gallery, right click on it and select properties. Then highlight the address in the box and copy it. You go to a "reply" box and across the top, the next to last icon on the right, looks like mountains, open that. You then paste what you copied in the line. It will shhow up in the reply box.
Old Apr 9, 2008 | 05:22 PM
tank1200's Avatar
Old Apr 9, 2008 | 05:23 PM
tank1200's Avatar
Hey it worked, thanks alot man, i was copying the link from my address bar thats why it didnt work, thanks again!!!
PS I love those roush wheels
You need to get that rear down!
Old Apr 9, 2008 | 05:24 PM
tank1200's Avatar
Thats the next thing coming, this weekend, it does look a little retarded
Old Apr 9, 2008 | 05:25 PM
You are welcome. Thanks on the wheels, just got them recently and I really do like them.
Old Apr 9, 2008 | 05:27 PM
tank1200's Avatar
Even though its 4 wheel drive i would like to lower the whole truck a little, i only use 4 wheel drive in winter and at the boat ramp, never off road. havent seen any lowering kits for the 4 wheel drive, im sure they are out there.
Old Apr 9, 2008 | 05:29 PM
azmidget91's Avatar
djm makes a 2.5/4 and a 3.5/5 drop for 4x4
i have a 2.5/5.5 i used thier 2.5/4 kit then removed the lifting hanger and used coilover shocks in the rear to get the desired hight
Old Apr 9, 2008 | 05:30 PM
yep. You removing the blocks?
Old Apr 9, 2008 | 05:31 PM
azmidget91's Avatar
o yeah and the 4x4 has a lifting block in the rear stock, just remove those blocks and get shorter u bolts and youll be droped about 2" but that will only take you down to the stock 2wd hight so 2" shackles will get you about level
Old Apr 9, 2008 | 05:33 PM
tank1200's Avatar
Im gonna pull the blocks this weekend. make it look alittle better.
Old Apr 9, 2008 | 05:44 PM
tank1200's Avatar
Thanks for the info, do you happen to have a web address handy. Thanks again!!
Old Apr 9, 2008 | 06:07 PM
azmidget91's Avatar
http://www.djmsuspension.com/Product...4F150Parts.htm
Old Apr 9, 2008 | 06:19 PM
tank1200's Avatar
Thanks for the web address, do you think i could remove the rear blocks, install drop shackles, that would give me 4" drop in the rear and then just replace the front control arms with there 2.5 drop arms. would that work.
Old Apr 9, 2008 | 06:45 PM
azmidget91's Avatar
well the 4" drop they are reffering to is for a truck without the blocks, so yes taking the blocks out and using drop shackles will lower the rear 4" but compared to a truck using their kit you will be 2" higher, also would make your rear 2" higher then the front.
so with 2.5 arms and removed blocks and shackles you would have a 2.5/2 drop which would leave your rear higher then the front
so removing the blocks and adding the shackles will get you level with your current front suspension.....
