help!!!!!! im stranded and I need help with my edge
Old Mar 14, 2008 | 07:49 PM
f150silver05's Avatar
Lightbulb help!!!!!! im stranded and I need help with my edge
My edge is throwing these weird throttle codes and has screwed up my truck. Won't even let me start. Turns over and dies. Even on the stock tune with the egde unplugged. It won't clear the dtc codes im getting no matter what I do. I now have my battery unplugged completely hoping that that will clear my comp. How long do I have to wait for this or any other ideas on how to fix the problem. Im on my pda so I need a response asap!!!!! And im in the middle of a wheelin spot that only a lift truck and a driver with my tree weaving skill, could get back too. So no just call a tow truck suggestions.
Old Mar 14, 2008 | 07:53 PM
06F150STX's Avatar
keep your bat unpluged for 15 min. if that does not work for some help from up above. sorry, i have never had that hapen to me before.
Old Mar 14, 2008 | 07:58 PM
Screw-Me-05's Avatar
Did something get wet? try the battery unplug trick and see if that gets you going
Old Mar 14, 2008 | 08:04 PM
I had it unplugged for about 10 minutes and that didn't work. Im gonna wait till 830 and try again and if that doesn't work then ill take my edge and leave. Go home and update and see if that helps. If that doesn't do it then I don't know what im gonna do.
Old Mar 15, 2008 | 12:02 AM
Jolly_Green_Giant's Avatar
I've had something similar happen. Call edge and have the truck, pod, phone, and internet handy. They have a few things that they can try.
However none of them worked for me. I ended up having to tow it to the dealer and them reflash the computer.
Was also user error on my part. Not edges fault.
Old Mar 15, 2008 | 12:19 AM
wrench007's Avatar
I don't have the edge, But try going back to stock tune. Crank it over at wot, give it a few seconds and then try and start normal with a little throttle. It may not have anything to do with the edge at all. Just for the hell of it. Worked for me one time a couple years ago, glitch in the computer I'm guessing.
Edit- Hasn't happened since.
Old Mar 15, 2008 | 01:26 AM
I think my throttle postioning sensor went bad cause i tried clearing the tunes my blkngolds x cal2 but that didnt work either. Keep getting the same 6 codes about my electronic throttle sensor. Any idea on a price or how hard of an install.
Old Mar 15, 2008 | 01:32 AM
Adam06FX4's Avatar
Registered User
when did this happen? was it right after you changed a program? i too had this happen to me with my edge and a reflashing the pcm was the only fix. edge had to send me a new unit also.
Old Mar 15, 2008 | 01:40 AM
wrench007's Avatar
Item Part Number Description
1 14A464 Throttle position (TP) sensor electrical connector
2 W707535 TP sensor screws (2 required)
3 9E928 TP sensor
Don't know the price, have to check it tomorrow.
Old Mar 15, 2008 | 01:52 AM
wrench007's Avatar
Whoops, another double post, Damnit
Old Mar 15, 2008 | 02:04 AM
Definitely was not the edge that caused your problem. I hate it when people jump to conclusions like that about the edge.
Hope you get things worked out.
Old Mar 15, 2008 | 05:52 AM
risupercrewman's Avatar
Just another reason not to Void your warranty with aftermarket garbage..........
Old Mar 15, 2008 | 08:03 AM
markshickjr's Avatar
I think it may be your throttle positioning sensor i had the same thing happening to my last truck 99 150
Old Mar 15, 2008 | 08:24 AM
wrench007's Avatar
Forgot to ask, Is your wrench light on? If so check out TSB 05-14-4
Old Mar 15, 2008 | 09:08 AM
beckerjs's Avatar
I'm fed up with this Edge caused my tire to go flat chit
