Upgrade speakers
Old Feb 28, 2008 | 02:09 PM
150 flareside's Avatar
Upgrade speakers
Wondering if upgrading the stock speakers to Infinitis' would change the sound to my stock single cd radio. Want to keep it stock. What other speaker packages would work for an improved sound. Don't want to blow my ears out. Just an overall upgrade in sound quality.
Old Feb 28, 2008 | 02:14 PM
attworth's Avatar
Lookin to spend a lot or a little?
I know you want to keep your stock radio, but really, any speakers you get won't be nearly as good as with a better radio.
If you want to spend a lot, look at something like Eclipse.
If you want to spend sub 100$, maybe look into some Pioneers. They sound better than stock and are maybe 50$ a pair. Alpine also has some fairly nice speakers for about 100 bucks.
Old Feb 28, 2008 | 02:39 PM
STX4MX's Avatar
I put some pioneer 3 ways in mine.
It sounds a ton better. Even with the stock radio.
Take a look at
www.crutchfield.com
They tell you what will fit, and what wont. Plus you get wiring harnesses, and detailed installation instructions.
I get all my stuff there.
Old Feb 28, 2008 | 03:17 PM
Myren's Avatar
Pretty much any decent name-brand speaker will improve the sound. I had a '97 Ranger and got some Polk 5x7's that I matched up to the stock H/U and no amp. Huge difference! I could hear more depth to the sound and everything was clearer. The one's I got were on sale for like 1/2 off the second pair. A lot of it depends on how acute your hearing is and what you're looking to get/spend, but you should be able to improve things for $150-$200.
Now the question is, who is gonna be the first to disagree w/ me?
Old Feb 28, 2008 | 03:20 PM
birddog_61's Avatar
Ok do you wan't to run a sub also? Do you want to amplify them to get better sq and get louder? If you just put new speakers on your existing setup you will see a slight gain in sq(sound quality) and just about any speakers will be better than the stock ones.
If you want to make it sound worth a darn look into a product like JL audio's cleansweep or other oem interface products. What these will allow you to do is keep your stock radio and run amplifiers for a sub and component speakers. There are other products out that will let you do this much cheaper than the Cleansweep they are called a "line out converter" these will tap into the speaker wire behind the radio and change it over to RCA. This will not sound as good as the cleansweep or as good as and aftermarket cd player but it will sound fair superior to the stock radio.
If you are trying to do it cheap I would do this, buy a line out converter and this amp
http://ikesound.com/product-product_id/3601
This is a very good amp for component speakers and will give you plenty of power. I would then put these speakers in.
http://ikesound.com/product-product_id/4829
If money doesnt matter then go with these
http://www.edesignaudio.com/product_...a9e14854f3e7e4
http://car.rainbow-audio.de/products...n=9&art=231064
Blake
Old Feb 29, 2008 | 12:47 AM
Tbird69's Avatar
I pulled the stockers and replaced them with Pioneer 2 ways in the front and Pioneer 3 ways in the rear. I also went the extra step of buying a Pioneer 4 channel amp and connected it through the speaker leads to the HU, then I ran an RCA cable from the Pioneer amp to an Alpine amp I already had and used that for a sub. The stock HU sounds pretty good, there's enough bass to shake the rear and side view mirrors.
Old Feb 29, 2008 | 11:02 AM
freekyFX4's Avatar
Blake
Don't buy from IkeSound...they suck!
Old Feb 29, 2008 | 03:28 PM
OK, how about if I buy a upgraded stock 6 disc changer or an audiophile head unit. Will the sound be better with the 6 cd head or better with the audiophile. I don't want to go thru the bother of buying a sub. What my question is, is the 6cd changer head unit a more powerful head unit than the single?
Old Feb 29, 2008 | 07:49 PM
jgonza5's Avatar
The 6-disc changer is definitely weaker. I don't know the wattage difference, but I swapped my Single CD with my Dad's 6-disc non-audiophile (since he only uses sirius). With the 6-disc unit and pioneer premier 4-way 6x8s ($115 to the door for two pairs on e-bay), I have to crank the radio to 75% volume to get the same sound output that 25% volume produced on the single disc (same speakers).
More distortion is produced when running these stock radios at high output levels, which results in some sound quality loss.
Old Mar 1, 2008 | 07:25 AM
Wow, that surprises me about the 6cd H/U. I guess I will look for a audiophile H/U on ebay. Those pioneers work well, huh?
Old Mar 2, 2008 | 11:07 AM
jgonza5's Avatar
Yes, they sound better than the stock. I can't say I can hear difference between the 4-way and a 3-way. I went with premier for the two year warranty.
Old Mar 2, 2008 | 12:31 PM
I just bought a pair from Crutchfields, 3-way for 79.00. Hope I like them.
Old Mar 2, 2008 | 08:45 PM
birddog_61's Avatar
I just used that site to show the products, I bought an amp from them once and it took 3 months to get it to my door. By that time I had already bought another amp from a different place and just sold that one. I guess I should have included in my post to not buy from Ikesound it just slipped my mind.
Blake
