CB radio
Old Feb 24, 2008 | 02:17 PM
CRF250rider1000's Avatar
Originally Posted by cndcowboy
Where do you run your coax into the truck? I have a mag mount with 1/4 inch cable and am trying to find the cleanest way to run it into the truck. The cable is way to thick to go in through the third brake light.
ok go under the left side of your truck, look for a small rubber grommet. Take off the long black panel on the inside floor of your truck it runs along the whole length inside. (looks like diamond plate sort of) Then towards the way back pull the BIG bundle of wires to one side and you will see it from the inside. Just pop it out, feed the coax through, then slice the grommet and put it back in. Then just run the coax down the left side next to the wire bundle and up the left side of the dash to where you want. I don't have any pics but you'll find it easily
Note, the plastic piece may be hard to get up, but you can just pull the rubber stripping up a little and pull the metal clips off once you get the whole piece off. Then put the metal clips and rubber stripping back in it's place and when you put the plastic back on it will snap right in place
Old Feb 24, 2008 | 02:27 PM
cndcowboy's Avatar
Thanks, that is where I was thinking of running it into the truck, thanks for confirming that it works. I just need to run it into the backseat where my cell phone booster is, so no worries about getting it up to the dash.
Now part two, how do you run the wire on the outside of your truck? Do you just let it hang down the back? Does it flap/knock in the wind? I have been trying to track down adhesive cable clips and not been successful. I found one company that makes them on the other side of the country and I have to buy minimum 200 clips, it seems that may be my only option.
Old Feb 24, 2008 | 02:58 PM
Mine just hangs just leave a little slack because the truck can flex. It hasn't given me any issues at all
Old Feb 24, 2008 | 03:06 PM
NoLongerJeepin's Avatar
those clips your thinking of can be found at walmart for around $5 in the automotive section
Old Feb 24, 2008 | 03:22 PM
cndcowboy's Avatar
Thank you for your answers.
I'll check that out. I have been to auto parts stores, cell phone installation places, CB installation places and no one has them or knows where to get them. Hopefully the Canadian walmarts carry them.
Old Feb 24, 2008 | 08:51 PM
2006M50B's Avatar
Same way I have mine run, wires hang down loose and run in the passenger side under the sill plate in the grommet in the back, no problems yet, and with tinted windows you can barely see the cables running down the back window
Old Oct 19, 2008 | 11:14 AM
tito11304's Avatar
go to a truckstop they have everything you need even those clips. it'll cost you a little more but it's all there.
Old Oct 19, 2008 | 03:46 PM
Wow this is an old thread
Old Oct 19, 2008 | 04:52 PM
Jolly_Green_Giant's Avatar
Save yourself the hassle and try to wire it up to the battery. That is your only sure bet that you will get "clean power" so that you won't hear engine noise on the radio
Ditto. I've done it several ways over the years and it has proved true.
I run a Cobra 25 and a Cobra 29 Both have served me well for over 11 years now. Both have been turned up and oddly the smaller 25 puts out more power regarless of the antenna within' reason. 29 has the built in swr meter but the built in ones are rarely accurate.
I have run firesticks both single and co-phase and they worked quite well.
My Wilson antennas however both out perform. I run a wilson 1000 trucker with the 25 and a Wilson "lil' Will" with the 29.
Whatever you get take it to a good C.B. shop and get it peaked and tuned. If you don't want to do it yourself also have him/her use a good SWR meter to set the antenna. Note: the good c.b. shops rarely look reputable. ask around.
Old Oct 20, 2008 | 12:51 AM
Impact9's Avatar
Sure is! and JGG fell for it muahahha!
Old Oct 20, 2008 | 07:32 AM
No fair! I was really tired!
Old Oct 20, 2008 | 08:21 AM
Excuses excuses Jeeze I posted that stuff when I was up at Michigan State and it was snowing outside
