How do you mount bicycles to an f150?
Old Feb 24, 2008 | 07:22 PM
  #31
Mojave F-150's Avatar
What I use http://www.performancebike.com/shop/...tegory_ID=4413
Works great. Relatively cheap too. When not in use is hangs on the wall. If it is just me, the bike gets tossed in the back. As "T" said, it is a mountainbike it will get scratched and if yours isn't, let me borrow it.
Old Feb 24, 2008 | 08:58 PM
  #32
Raoul's Avatar
Certified Goat Breeder
25 Year Member
Originally Posted by Tylus
sorry, that's my method. you could get a 2x6" and cut it to fit into that slot behind the fender well. then get a mount like the guys above posted.
easy to install, and no bed holes get drilled...plus the 2x6" helps to keep cargo in the back 1/4 of the bed instead of sliding everywhere
I use that method.
The bike-tites are about $25 at the bike shops.
I use two 2x6's stacked.
Old Feb 25, 2008 | 04:18 AM
  #33
Tornadom's Avatar
Sweet, I have a nickname on here already!
ToRn also works... or tornado.
Old Feb 25, 2008 | 12:16 PM
  #34
pignjig's Avatar
Bungee cord bikes standing up to cargo hooks. One bike per side or even two bikes per side if you do two bikes per side use a towel between bikes to keep bikes from getting scratched. I wouldn't get a hitch hook up bike hauler unless you are taking a long trip and need truck bed for storage.
Old Aug 21, 2008 | 04:00 PM
  #35
ecof150's Avatar
For those with a crew cab, is it possible to fold up the rear seat and get two bikes side by side in the back?
Old Aug 21, 2008 | 04:09 PM
  #36
risupercrewman's Avatar
I use a trailer hitch bike rack, they work the best!...........
Old Aug 21, 2008 | 06:04 PM
  #37
XLT-FX4's Avatar
Bed space is pretty precious when I need to pack all our stuff for the four of us when we go away. So I bought a decent Yamika 4-bike hitch mount carrier.
Old Aug 21, 2008 | 06:39 PM
  #38
LeanNCut's Avatar
Exclamation
Since I neither like the hitch-mount bike carriers nor the universal "clips" and shower-curtain style "bars" I use the ratchet tie-downs. They're somewhat of a pain to setup/remove but sturdy and the bikes can stay saddle-side up.
Old Aug 21, 2008 | 07:34 PM
  #39
YDM's Avatar
YDM
First time poster, long time reader. This is what I use:
I have two of them. You don't have to remove the front tire either and they also lock so at least it will slow down a thief somewhat. This is by far, in my opinion, the easiest way to transport bikes in a pick-up bed. Here is where I bought them from:
http://www.cargogear.com/OneItemInfo...tnum=THINSTAGR
Old Aug 21, 2008 | 08:15 PM
  #40
JeremyGSU's Avatar
you can buy the clips that mount to anything that you take the front wheel off and mount it to it.
http://www.amazon.com/Pyramid-Quick-.../dp/B0006JHU5I
Then just mount those on some scrap wood and make a little stand out of it.
That's exactly what I did. I measured the width across my bed and accounted in the angles for it. I went to Home Depot and had them cut a board off the dimensions I got and then cut the angles at home myself so it fit right into the bed before the wheel wells. I put two on each side, painted the board black and it worked great. Boards never moved more than an inch or so.
Old Aug 21, 2008 | 11:19 PM
  #41
Skrewd's Avatar
Wood is now Painted...
Holds 4 Bikes
Old Aug 22, 2008 | 02:08 AM
  #42
sbchris's Avatar
when I shuttle I hang them over the tailgate with a moving blanket.
When I have two or three downhill rigs in the back I just use tie downs.
Old Aug 27, 2008 | 01:02 AM
  #43
gixxerjasen's Avatar
I have a scab and I'll say that it's a PIA to get one bike in there (front wheel has to come off) so I think two might not be impossible, but would be durn near close.
YDM, I'd forgotten about those. I looked into one for my Ranger for the locking ability but tossed it out due to non locking tailgate. Never even thought about it again since getting the F150.
Old Aug 27, 2008 | 01:22 AM
  #44
gpaje's Avatar
I used a Thule Bedrider rack for my old F150. For the Expedition, I use a hitch mounted bike rack.
Notice on the truck bed rack, I mounted the bar inside the bed where you would mount 2x4s. Sits better on the bed, holds tight, and easy to take off when not in use.
Old Aug 27, 2008 | 04:56 AM
  #45
ecof150's Avatar
gpaje, do you have an extended cab? Are you able to close the tailgate with the bikes in?
