custom E-Fans
Originally Posted by ELVATO
I used a ratchet to hold one of the water pulley bolts, then loosened the fan with a fan wrench.
As a side note, I'm going to get Mark VIII fan tomorrow.
Figure it'd better than the single 16" one I have there now.
Anyone need two 16" fans?
Originally Posted by ScottFF00
Go with the DC Control FK35 or FK60. Here is there website. It has a lot of general info as far as EFan and controllers go also.
www.dccontrol.com/catalog2008.htm
Originally Posted by purpony
JUNK!!!! I had one on my mustang and it burnt up. Great concept but overall quality was horrible. The worst customer service also. I ended up thowing it out and building my own.
Marc(purpony) posted on the mustang forum that he was happy with the product, this was nearly two years after the purchase. Two weeks after that, he posted on the same forum that it never worked correctly.
Regarding the customer service, I do try and help when a product is out of warranty, regardless of whether or not it's a customer caused problem, but I felt that he was both dishonest and underhanded in his approach to a solution, which left me with very little incentive to help him out.
If he disagrees with anything I've said here, I'd be more than happy to document it.
i'm about 95% done with my install, using the derale controller.
where did you guys hook up to an ignition source and (i can't remember if i asked or not) whic is the positive a/c wire? ( i thought it was the grey with red stripe)
Unplug connector on the compressor and touch the signal wire to each of the wires with the AC in the on position. Which ever one turns on your fans is the one you want to connect to.
As for the ignition one i have not connected that one yet. Im going to look for a wire thats live with the ignition on close to the battery as thats where i mounted my DC controller.
i used the yellow wire that was part of the factory electric fan clutch. and the ac compressor wire i used was white. i have pics here https://www.f150online.com/forums/sh...d.php?t=328571
I don't see that connector you tapped into for the ignition.
Originally Posted by Irish FX4
What year is your truck?
What factory electric fan clutch? Its mechanical on the factory fan.
if your fan doesnt have this, that would explain why you cant find the wiring harness that i used. the harness is the one that powers the electric fan clutch
WOW!
Mine does not have that! Mine is the old style with the thermostaticllly controled clutch. Do you no any place i could tap into for ignition power? Close to the battery.
Was thinking about the headlights as we have day time running lights here and theres power on the lights all the time.
WOW!
EDIT: just checked the truck. i can see 3 small wires attached to the alt. (not counting the large wire thats hooked to the battery. i would be willing to bet one of them is 12v switched. if not, the factory computer is right there next to the battery, you know one of them has to be a switched source (more then likely a few of them) so just start testing. if you can figure out which wire runs to the radio, ac fans in the cab, or any other electric devise you have that only runs when the truck is on, then find that wire under the hood. that would be my last resort tho.
i havent really looked at the truck as far as wiring goes but i know on my mustang, the alternator has a green wire running to it that is a switched 12v source. but this is a 92 mustang so technology has probably changed just a little since then.
Ill check my alternator first then your other suggestions.
theres a harness between the battery and firewall, it's clipped on near the seal for the hood. it has 3 wires that are switched on the ignition. the a/c wire is still pissin me off though... bigtime.
https://www.f150online.com/galleries...582&anum=15947
