Vibrating ash tray
Vibrating ash tray
I've got an '04 FX4 w/ the flow through console. When its cold, the ash tray seems to rattle a lot. Can get pretty annoying during those mornings into work. But anyway, has anyone had this problem and found a quick fix such a strategic location to put a piece of felt or something? Thanks.
also do a search on it.
I think there was a TSB out on this
Yep, here it is:
TSB Main Page
TSB
06-19-13
* RATTLE FROM TIP OUT ASHTRAY - VEHICLES BUILT PRIOR TO 1/1/2006
Publication Date: September 15, 2006
FORD:
2004-2006 F-150
LINCOLN:
2006 Mark LT
ISSUE:
Some 2004-2006 F-150 and 2006 Lincoln Mark LT vehicles equipped with tip out ashtrays, built prior to 1/1/2006, may exhibit a rattle noise from the ashtray while driving over bumps or washboard roads, usually when the ashtray is in the closed position.
Yep, here it is:
TSB Main Page
TSB
06-19-13
FORD:
2004-2006 F-150
LINCOLN:
2006 Mark LT
ISSUE:
Mine did the same thing so I just took the tray out of the holder and now theres just a bigger hole and no more rattle.
This ash tray (ashtray) rattle is an easy fix. I acquired a strip of tape-backed foam from work, cut a few small pieces, and wrapped the three (3) little pegs at the bottom of the ashtray assembly. It's easy to remove/reinstall. I haven't had a rattle since!
Here's another thread about it:https://www.f150online.com/forums/sh...d.php?t=263430
