Rear End Clutch packs
Old Feb 6, 2008 | 10:59 AM
mikey88's Avatar
I had these replaced under warranty, but they are shuttering again. Anyone know what it will cost to have this repaired? No more warranty!
Old Feb 6, 2008 | 11:28 AM
05RedFX4's Avatar
I don't know how much it would cost to repair your OEM LS unit, but since it will be on your dime, you might consider an aftermarket unit. You can get a Truetrac unit for the 9.75 diff for less than 5 bills, and they a simple bolt-in, no special tools needed.
Old Feb 6, 2008 | 11:37 AM
Huitt24's Avatar
your looking at 125 for the clutch paks and then the labor to install them.
Old Feb 6, 2008 | 12:41 PM
Tbird69's Avatar
A cheaper solution to try is to add more friction modifier. Drain the diff, add about 6-8oz of modifier (Ford calls for 4), refill the diff with 75W140 synthetic gear oil. Ford used to spec 75W90 but has since changed that to the heavier oil.
Old Feb 6, 2008 | 12:47 PM
Winsurfer76's Avatar
I asked the service manager at the local stealership about what I could do with my chattering clutch packs. He said I could try the cheap route of adding friction modifier and driving it around awhile or the expensive route of a out of warranty clutch pack rebuild.
I'm a cheap SOB and went that route. That worked for me although YMMV.
