Little help needed...
Old Feb 4, 2008 | 08:42 PM
DuezezWild's Avatar
Question Little help needed...
Today my blinkers went out. Turn signal control on the steering column engages just no blinkers, but the hazards work. Pulled the fuses for the turn signal lamps and its good. Checked the wipers and they still work so I don't think there is a problem with the control mounted on the steering column. Is there something else I need to be looking for. I looked to see if there was another fuse to check and didn't see one noted. I know there is something I'm missing. Any suggestions?
Old Feb 4, 2008 | 10:23 PM
maro's Avatar
Check around and try to locate the flashers, most of the time there will be one for the turn signals and a seperate one for the hazard lights.
Old Feb 4, 2008 | 11:28 PM
JD790's Avatar
Try tilting the steering wheel to a different position - then try the blinkers again.
Old Feb 5, 2008 | 08:56 AM
DuezezWild's Avatar
Thanks for the help, got in the truck this morning and now they work. Just pulled more fuses I thought it could be and they all checked out. Was giong to take it in this morning for service to look at it and magically they work. I'm glad they are working but just concerns me that I never could really located the problem that was causing it. We will see how long before it happens again.
