Auto Lock & Flow Through Shifter
Old Feb 4, 2008 | 07:56 PM
StickyF250's Avatar
When the truck is unlocked and it begins to move, i think at about 5mph or so the doors are supposed lock. I recently changed my column shifter to a flow through console shifter with the dash complete as well...
I wired everything up and everything works fine now, except the auto lock feature. I think i recall someone else who did this mod having similar problems.
Has anyone who converted to a flow through console experienced the same problem and had any success fixing this problem or anyone possibly know how to fix it so it will auto lock again?
Old Feb 4, 2008 | 08:28 PM
FX4&EXCURSION's Avatar
No problems here. I would try and reactivate that feature. I believe in the owners manual, there are steps to accomplish this utilizing the key FOB. Good luck!
Old Feb 4, 2008 | 11:22 PM
StickyF250's Avatar
I'll try that in the morning and let you know...
Old Feb 5, 2008 | 03:36 PM
StickyF250's Avatar
That did not do it! Once you follow the instructions your supposed to hear chirps or beaps, i did not get either..
Old Feb 5, 2008 | 03:46 PM
StickyF250's Avatar
Ok so i tried it with my Key less entry pad on my keys and that did not work. So i tried it with the key less entry door pad, nothing. Next i went to the unlock/lock button on the door inside the vehicle and it worked, so now i have auto lock enabled again.
