How do I deactivate the belt chime when the buckle is no working?
My drivers side belt buckle switch is not working, so the belt chime comes on everytime.
I got access to a new drivers side wire harness and buckle/pretensioner assembly and it was not the problem. Most likely a connection problem at the cluster or in-line to IP wire harness.
I know the buckle unbuckle 9 times process (already did it on pass side) but since the buckle switch does not work, I cannot deactivate it. Is there another way of doing this? OBD II? (I don't want to start pulling my truck apart if there is a different way of doing this).
Thanks.
Thanks.
http://www.fordf150.net/howto/beltminder.php
there ya go good luck!
edit: sorry i was impatient and jumped. i would try taking apart the buckle and finding the switch.
