k&N CAI HELP!!
Old Jan 29, 2008 | 04:21 PM
ldahlberg's Avatar
k&N CAI HELP!!
During the past month my truck makes really loud noise when going over 60 mph. The noise is constant and sounds like to much air is coming in the engine compartment. I have narrowed it down to CAI. K&N told me the problem is with the idle air control valve. Any ideas???
Old Jan 29, 2008 | 04:22 PM
i.ride.suzuki's Avatar
These engines don't have a IAC...
ThumperMX113's Avatar
Do you have an Edge?
Old Jan 29, 2008 | 04:23 PM
ldahlberg's Avatar
I have TP tunes and have had the tuner and CAI since 10/6 without problems
Old Jan 29, 2008 | 04:25 PM
What is TP? Toilet Paper?
Old Jan 29, 2008 | 04:27 PM
ldahlberg's Avatar
I have Toyer Performance custom tunes
mSaLL150's Avatar
Troyer Performance.
I run their tunes with my K&N with no problems. I would call Troyer about it and see if can help you out.
Old Jan 29, 2008 | 04:29 PM
Originally Posted by mSaLL150
Troyer Performance.
Oh ok, Thanks!
Do you have Fog Lights?
Old Jan 31, 2008 | 12:28 AM
xlint1's Avatar
Check the hose clamp at the filter.
Check the MAF sensor seal.
Check the breather hose and fitting.
Check the clamp at the top of the throttle body.
Old Jan 31, 2008 | 01:10 PM
bamorris2's Avatar
ROLF
Old Jan 31, 2008 | 02:37 PM
StickyF250's Avatar
What do you mean too much air in the engine compartment??
I have a K&N Intake 63-2556 Kit and the only noise i have is an annoying Whistle noise when i hit the gas on acceleration and once at highway speed 60-70 i cannot hear it with the radio on.
Are you talking about a whistling noise or something different?
Anyone know how to get rid of the whistle or is just normal for a CAI system??
Old Feb 2, 2008 | 03:20 AM
xlint1's Avatar
No whistle on my FIPK for 5.4L. Check all your clamps.
Old Feb 6, 2008 | 12:28 PM
ldahlberg's Avatar
I checked all clamps and seals and they all are tight. I called Toyer Performance and they said to unplug the battery to clear the computer. That worked for a short amount of time but the noise is still there. It seems like it is worse when it is cold out. Any other suggestions this noise is pissing me off.
Thanks for all the suggestions!!!
Old Feb 6, 2008 | 02:36 PM
Hitched_Gibson's Avatar
There was a thread not long ago about the noise. I think it turned ou tto be an alternator.
