74K mi. upper ball joints bad
Old Jan 31, 2008 | 12:20 AM
xlint1's Avatar
Originally Posted by NCSU_05_FX4
Agreed.
How much did the replacements run you xlint1?
- NCSU
Haven't done it yet. I'll let you know. I guess mine's par for the course as mileage goes on these. I thought that was way too soon, but I guess not? Hopefully some noobs read this and decide against the leveling kit. Wish I did...
Old Jan 31, 2008 | 08:27 AM
dkstone05's Avatar
Originally Posted by ford2004F150
I put on the AS 2.0 at 24K and upgraded to the rancho 4" lift at 50K.
I must say you could see the signs of wear the AS kit did.
Most of the wear seemed to be at the tie rod ends... not so much the balljoints. The rubber boots on the top ball joint and tie rod end seemed to be deformed and leaky. The tie rod ends seem loose.
The ride sucked with the AS 2.0 and I am glad it is gone!
Would I do it over again? No way!
How did the ride suck with the AS? It doesn't change the shock or the spring compression. My truck rides more rough but that is because of the stiffer tires. When I put the factory tires back on for the winter it rides as smooth as it did from the factory.
Old Jan 31, 2008 | 02:15 PM
Bulldogbud's Avatar
Just do it ur self its a hole lot easier in the pocket book just be careful and not screw up your alignment when replacing em cuz i did
Old Jan 31, 2008 | 03:00 PM
ThumperMX113's Avatar
But it does reduce suspension travel.
Old Jan 31, 2008 | 06:42 PM
dkstone05's Avatar
sure does ....but unless your driving offroad where that travel is needed it doesn't matter. For everyday driving it has no effect on ride quality, unless you are driving off into some major potholes, which if that's the case the person needs to concentrate more on avoiding holes. (Unlike my wife, every time she sees something to hit on the road I think she aims for it )
Old Jan 31, 2008 | 07:47 PM
chazf150's Avatar
Originally Posted by bamorris2
What are the tell-tell (or is that tale-tale) signs of upper or lower ball joint failure?
Signs- Started hearing some poping noise. And noticed a tear on 1 lower ball joint. For the uppers - got very noisy (sqeaking)
Old Feb 2, 2008 | 03:17 AM
xlint1's Avatar
You should try driving in NE Ohio. You'd be pulled over for DUI suspicion if you were to try and dodge all the potholes.
