Problems Installing Shifter! Please Help!!
Old Jan 16, 2008 | 06:38 PM
TonkaTruck33's Avatar
Exclamation Problems Installing Shifter! Please Help!!
how in the hell do u put the shifter back together!?? ive been trying for the past hour and i still cant put it in, i bent my spring.. how do u put it back on??
i put the spring on the mount then wat?
do i just put the shifter over it? do i need to take the button out? what do i do?
Old Jan 16, 2008 | 06:43 PM
anyone?
Old Jan 16, 2008 | 07:10 PM
Ftruck05's Avatar
All right bro, here ya go. Instructions straight from my Haynes manual..
Removal
1. Set the Parking brake, then place the shift lever in N
2. Remove Center console side panes and top console shift cover
3. Separate the shift cable end from the shift lever usina a screwdriver
4. disconnect the shift cable from the shift assemble mounting bracket.
5. Disconnect the shift lock solenoid electrical connector.
6. Remove the 4 bolts and remove the shift lever assembly from the floor.
Installation
7. Installation is the reverse ot the removal procedure
That is as detailed as this book gets.
Old Jan 16, 2008 | 07:11 PM
Ftruck05's Avatar
I bet you didnt set the parking brake or put it in neutral yet have you?
Old Jan 16, 2008 | 07:15 PM
thankz, but im talking about the spring inside the shifter,
this one, do i just set it there, and then slide down the shifter??
Old Jan 16, 2008 | 07:20 PM
comon people i cant drive my truck without a shifter...
Old Jan 16, 2008 | 07:33 PM
I12AV82's Avatar
No idea! You can always take the lid off and use the shift-interlock override to take care of it - so it's driveable, just ugly.
Old Jan 16, 2008 | 07:41 PM
wow...I FREAKIN BENT THE SPRING PRITTY BAD.
Old Jan 16, 2008 | 07:46 PM
Ftruck05's Avatar
I havent been in a FX4 lately. Does the shifter have a button on the top or a lever in front???
Old Jan 16, 2008 | 08:53 PM
cndcowboy's Avatar
lever in front
dosent anyone know how to put it back?
Old Jan 16, 2008 | 08:59 PM
Walk to the nearest auto parts store and buy a repair manual. Never attempt a task unprepared.
Old Jan 16, 2008 | 09:04 PM
ive had one for the past 3years, nothing comes out..
Old Jan 16, 2008 | 09:17 PM
Ftruck05's Avatar
Lever in the front huh??? Well I dont think the spring would go on the top as you have it picture. Hmmmm, why did you take it apart in the first place???? I hope you learned your lesson, pay more attention next time! Hope someone can help you out, its probly going to be something stupid as hell that you will kick yourself in the *** for not seeing on your own.
Old Jan 16, 2008 | 10:08 PM
thats exactly wat im thinking, the spring was already there when i took it off, the reason why i took it off was cuz im painting it black since it was all faded. but i mean someone has to know...
