If you have a rough idle OR poor gas mileage please respond
Old Jan 9, 2008 | 10:19 PM
mSaLL150's Avatar
2004 scab 4x4 80k miles
had a rough idle for a while, it also idled at really low RPMs. the edge didnt fix it. finally got troyer tunes and mentioned to him that i wanted it to idle a little quicker, its been perfect since.
a custom tuning specialist can fix all of these problem, and write specific tunes to improve fuel economy.
im averaging 13.8 around town and almost 18 on the interstate. K&N CAI, Flowmaster duals, Troyer 87 tune.
Old Jan 9, 2008 | 11:42 PM
Ballin STX's Avatar
where can I go to have my edge custom tuned??
Old Jan 10, 2008 | 12:13 AM
I12AV82's Avatar
I would be very interested in this as well ..
Old Jan 10, 2008 | 12:21 AM
mSaLL150's Avatar
contact Bill, his user name is ASEmechanic. he can help you with edge custom tunes, i believe.
Old Jan 10, 2008 | 12:28 AM
NoLongerJeepin's Avatar
I've got the 2005 4.6 with around 58k miles. im averaging around 13-18 with a driving style of about 4 or so. i had a rough idle for a few weeks and i got the fuel filter replaced as well as plugs and it fixed it. if its sitting around idling for more then 15 min then it gets a bit rough but nothing that i find weird.
Old Jan 10, 2008 | 06:35 AM
svt2205's Avatar
Ok, I'll bite...
98 F150 4.6, rough idle, 15 mpg
01 F150 5.4, rough idle, 14 mpg
03 F150 4.6, rough idle, 15 mpg
04 Expedition 5.4, rough idle, 14 mpg
07 F150 5.4, rough idle, 16 mpg
Unfortunately, rough idles with the Modular motor is common. Dealers, at least in my area, all say it's normal and there's nothing you can do. I'm going to see what I can learn using my autotap software, but not going to worry much about it.
So, where are we going with this list?
Old Jan 10, 2008 | 01:54 PM
Roodoo2's Avatar
Originally Posted by svt2205
Ok, I'll bite...
Im not biting on the modular motor idles rough thing, Ive been servicing Crown vics 4.6 since 94 when they came out, only a couple of about 50 cars ever had coffee cup shaking idle. The truck seems like secondary ign issue, but evidently it is "normal". We have a few vans and some F250 at work I will have to make a point to check them for this shaky idle.
Old Jan 10, 2008 | 02:22 PM
ThumperMX113's Avatar
I had the rought idle until I started using better oil, I went from using crappy castrol gtx oil and switched to using royal purple synthetic, all I gotta say is the rough idle was gone. I also noticed a gain in HP AND better gas mileage!
From now on thats all i will be running in my truck.
Really? .. you felt the difference in a oil change? That must be one accurate ***-o-meter you've got.
Old Jan 10, 2008 | 07:39 PM
JeremyGSU's Avatar
Wow. I'm glad to see I'm not the only one getting crappy fuel economy. I don't remember if my truck idled rough before or not but it idles just fine with my Troyer tune. Mostly idling at 650.
Old Jan 10, 2008 | 09:17 PM
BlueScrew4.6's Avatar
No No....I think he used one of these.....
http://kalecoauto.com/index.php?main...products_id=41
Old Jan 10, 2008 | 10:19 PM
tohi2care's Avatar
Originally Posted by 2005lariatky
Last few fill ups have been low 13's with Edge on Level 2. Next fill up is going to be premium on Level 3 and see if it gets any better.
What milage are you getting with 87 octane (regular) and no edge? Because isn't putting your Edge on lvl 3 and using 94 octane (premium) to get better milage pointless? Your spending more money to use 94 and it's on lvl 3 so obviously your going to be using more fuel then lvl 2.
Old Jan 10, 2008 | 10:24 PM
2005lariatky's Avatar
13-15 Without Edge. That was also before winter fuel and the gas station that I normally just started using a 10% Ethanol Blend. Also at first it was hard to keep my foot out of it. I have seen people on here that use Level 3 and are getting 17-18mpg.
Old Jan 11, 2008 | 11:03 AM
mkosu04's Avatar
Originally Posted by Oxlander
Go into the settings on the Edge Evo and bump up the idle RPMs by about 150. I did this and the rough idle is gone. It seems that with the cooler weather, we turn off our air conditioners and the engine rpms at idle drop too low, thus creating a rough idle.
On a scale of 1 - 10 for driving habits, I would rate myself as a 3. very conservative. I am averaging 16-17 mpg in mixed driving.
For truck info look at the sig.
Oxlander - I looked at my Edge manual last night and it doesn't say anything about the idle RPMs in the custom settings. How do you change this?
EDIT: nevermind... I found this posting https://www.f150online.com/forums/sh...d.php?t=315577
I guess its in the custom settings but they just don't talk about it in the manual? I'll try it after work today.
Old Jan 13, 2008 | 12:32 AM
Roodoo2's Avatar
that is not so unusual really, and without even using funky oils, just a fresh change of good oil can really make a diff in a lot of vehicles.
Old Jan 13, 2008 | 05:47 PM
Oxlander's Avatar
Were you able to get your idle adjusted? Did it smooth out your rough idle issue?
