Roush Supercharger ????
Old Jan 5, 2008 | 10:25 PM
fx4f150guy's Avatar
1. can you run an after market intake with the roush supercharger?
2. does it re-use the stock throttle body?
3. what size fuel injectors are yall using?
4. would you recommend running a cam?
any input would be great!
Old Jan 5, 2008 | 10:47 PM
FX4 Matt's Avatar
Registered User
You dont need to
2. does it re-use the stock throttle body?\
Yes
39#
No
The Roush kit is the best complete one out right now
Old Jan 6, 2008 | 12:57 AM
Matt 05'FX4's Avatar
I wouldn't, the kit comes with another one anyway
Yes
They give you new high flow injectors
Possible, but the stock setup works pretty well
Old Jan 6, 2008 | 02:25 AM
fx4f150guy's Avatar
so i could use the BBK 80mm throttle body? also do you know if the Granatelli Mass air flow sensor would work?
i was considering the S&B CAI but if it comes with an intake then nevermind.
Old Jan 6, 2008 | 11:33 AM
You could use that TB, but I think it would be useless due to the little adapter piece that the TB attatches to the S/C with. It is like a 90 degree elbow and unless you bore out that whole pipe and the S/C inlet then you aren't going to gain anything. It comes with its own intake and the MAF is built into the HUGE pipe right at the air filter and the tune is calibrated to work with that pipe and airflow readings so I wouldn't want to change that either.
