HID Help needed ASAP
Old Feb 23, 2008 | 02:57 AM
thenewbreed's Avatar
Originally Posted by noob2
i cant remember where i read this info but something about the wiring.not sure if its the power wire or the negative wire of both the foglights and the high beam share a common connection somehwre under the dash thats why whenever you turn the foglights on(auto or manual)it doesnt see the loop connection on the high beam and thats the reason why the high beam icon is lit.
you just need to find that connection and move the neagtive wire(if it is the negative wire) to another source and if its the positive wire..i think thats where you use resistor or relay to fool the wiring that it has a bulb connected to it.
i had my low beams and my fogs converted to HID and what i did is a pggy backed by HID(positive and negative) to the original wiring harness so i can still have my high beams working too but i also have the aftermarket HALO lights so i had tthe 2 bulb set up to begin with.
hope this helps.
old thread, but noob2 do you have any pics of your headlights
