Fuse help ASAP
Old Dec 18, 2007 | 01:50 PM
shaunakadub's Avatar
Fuse help ASAP
Hey guys/gals/things:
Does anyone have a link to the fuse layout in our 04+ trucks?
I have an 05 STX and I'm planning on installing my new Alpine tonight, problem is its cold as hell outside and I would like to keep the truck running while I install instead of disconnecting the battery. I figured I would be ok if I just remove the fuses that run the radio system.
If you don't have a link, does anyone know which fuses run the radio?
Thanks in advance! I'm pumped about installing the system tonight, so quick help would be greatly appreciated.
Old Dec 18, 2007 | 01:52 PM
i.ride.suzuki's Avatar
It is in your owners manual.
Old Dec 18, 2007 | 02:40 PM
Don't have one, hence why I asked here =p
So I'm guessing if its in the owners manual I'll be able to find it on that site that has the prinitings of our manuals in PDF format?
Anyone have that link?
Edit: Also forgot to ask... does anyone see any risk with doing this? I'm thinking as long as there is no power to the radio and components I wont run any risk... but you guys know more then I.
Old Dec 18, 2007 | 02:50 PM
http://www.motorcraftservice.com/?li.../05f12og5e.pdf
Old Dec 18, 2007 | 03:04 PM
turtle313's Avatar
you should be fine. I've installed several HU with out disconnecting the battery or pulling the fuses. How are you doing it? Cutting out the factory harness or using an adaptor? Just make sure to shut off the ignition when you plug in the harness and you should be fine even if you don't pull the fuse.
