Cruise Control
Old Dec 14, 2007 | 03:46 PM
Hestpeis's Avatar
Cruise Control
I lost my cruise control a few months back on my 2004 Lariat. Didn't get around to checking things out, but this past weekend it worked again?? Anyone experienced this??
Old Dec 14, 2007 | 03:53 PM
sysman_rick's Avatar
Post
Was your vehicle on the recall for cruise control ? If so,did you get the recall done ?
Old Dec 14, 2007 | 03:57 PM
Hestpeis's Avatar
Never got a notice, my model must not be on the recall list.
Anyone know if it the 2004 should have been?
Old Dec 14, 2007 | 04:04 PM
J-150's Avatar
you may want to check with your dealer just in case
Old Dec 14, 2007 | 04:08 PM
Hestpeis's Avatar
I'll give em a call next time it stops working...
Old Dec 14, 2007 | 04:10 PM
You don't really have to... just go here and type your VIN in.
http://www.ford.com/owner-services/c...ll-information
YOU DO NOT WANT TO DO THIS! If the recall has not been done the truck will catch on fire due to the cruise control wiring. I don't want to see your house catch on fire if you leave it parked in an attached garage.
Old Dec 14, 2007 | 04:22 PM
Hestpeis's Avatar
Thanks, I'll check it out...
The truck does not fit in my garage... Good news is that if I leave it outside and it burns, I can get a 2009, they should be out late next summer......
Old Dec 14, 2007 | 04:25 PM
Hestpeis's Avatar
[QUOTE=ManualF150]You don't really have to... just go here and type your VIN in.
Thanks. I went to the site "There are currently no recalls on this VIN."
I guess I have other issues going on...maybe it is a bad switch or something...
Old Dec 14, 2007 | 04:33 PM
[QUOTE=Hestpeis]
Good.
RoushF150's Avatar
[QUOTE=Hestpeis]
Just because the VIN doesn't match doesn't mean you don't qualify. I had that happen on my Explorer and they replaced the hood latch under the recall because the dealer inspected the item to ensure it was covered.
Old Dec 14, 2007 | 04:44 PM
Hestpeis's Avatar
Thanks, will check it out...
Old Dec 14, 2007 | 04:46 PM
osbornk's Avatar
The 2004 Heritage was included in the recall but the new body style was not.
kingfish51's Avatar
The new model F150, 04 up, were not included in the cruise recall. They have a different setup than the previous version.
Old Jan 7, 2008 | 01:29 AM
Bl.ai.r's Avatar
I have been having the same issue, intermittent cruise control in a 2004 Lariat. Sometimes it works, sometimes it just stops working while going down the freeway.
I did some experimenting and I can make the cruise control kick out if I push up two window switches at the same time. So it is something that is effected by current. Could this be caused by a bad relay?
Old Jan 7, 2008 | 01:50 AM
hoss66's Avatar
i used to have this problem with my 2000 f350 and my 1999 explorer never did figure out what the problem was before i got rid of them. totally different vehicles but same problem. would like to see if someone figures it out
