Underdrive pulleys
Old Dec 6, 2007 | 11:55 AM
05xlt5.4's Avatar
Underdrive pulleys
I have two questions;
1. does anyone make UD pulleys for the 5.4L 3v
2. I tow a 18' trailer occasioanly will this affect my towing? engine temp?
Old Dec 6, 2007 | 11:58 AM
05supercrew's Avatar
Troyer sells them.
Old Dec 6, 2007 | 12:33 PM
05extcabflare's Avatar
Underdrive pulleys slows everything down including your cooling. I tow a camper and people told me not recommended. I could possibly overheat my truck while towing.
Old Dec 6, 2007 | 12:34 PM
azmidget91's Avatar
i have a set that im not using
Old Dec 6, 2007 | 12:42 PM
i.ride.suzuki's Avatar
Considering (last time i checked) the HD pulley was -25% and the WP pulley was +26%. Giving you 1% more cooling.
Old Dec 6, 2007 | 12:51 PM
openclasspro#11's Avatar
zero issues on my 9000lb 3/4 ton van towing my race trailer~5500lbs in the hills of pa on the hottest summer days-phil
Old Dec 6, 2007 | 02:09 PM
Big Slick's Avatar
do the gains justify the price? i thought the general consensus was that bolt on's don't do enough to warrant them unless you're a freak looking for the last extra HP.
Old Dec 6, 2007 | 03:53 PM
mSaLL150's Avatar
UD pullies will help make you quicker right off the line, and you wont get that horrid high pitched squeal on high RPM downshifts. im thinking about getting a set.
Old Dec 6, 2007 | 04:29 PM
JeremyGSU's Avatar
I've been thinking about getting them too. I want to see my truck hit 15's and I think that will net the trick.
Also, if I'm not mistaken Troyer's page says they can help with towing so I'm sure he wouldn't sell them if they caused overheating.
Old Dec 6, 2007 | 04:33 PM
azmidget91's Avatar
like i said i have a set of used pullies ill let them go for $150 shipped
here is where i got them
click
Old Dec 6, 2007 | 05:17 PM
ONE04FX4's Avatar
Talking
according to the website it is underdriving the water pump and the carnk. wouldnt you have to put a smaller water pump pulley to speed it up?
Old Dec 6, 2007 | 06:03 PM
FX4 Matt's Avatar
Registered User
I had them before I got the blower I sold them for $100, They are worth that I did tow a boat every weekend with no issuse.
Old Dec 6, 2007 | 07:11 PM
I been doing a search on this. If I'm reading everything right. The crank pulley is smaller give you more torque and enlarge the water pump pulley for cooling. They are saying sometimes you have to increase idle speed. Also I read if you underdrive the water pump, it will slow the clutch fan which would cause overheating. Any opinions?
Old Dec 6, 2007 | 07:38 PM
More stress on the power steering. Instead of adding idle speed the best way to do it is increase #/min flow in the tune via the pressure transducer on the power steering. But i really don't know of anyone that actually does that, except me.
Old Dec 6, 2007 | 07:59 PM
GerRod's Avatar
I got a set of Motoblue pulleys I'll let go for $75 plus shipping.
http://www.rpmoutlet.com/04f150powerhyper.htm
