DIY Plug change on 5.4l 3v 2004 FX4 100k miles
Old Dec 2, 2007 | 08:51 PM
  #76
Nolo's Avatar
Originally Posted by ohboy44
You do know that you are supposed to turn them lose 1/8-1/4 then spray them and wait right?
What is the term I'm looking for..... ahh yes. Beginners luck. But I'm still glad you got them out without breaking any.
Yes. I have the TSB.
I took off all the COPS. I sprayed all of them without turning them and waited. I then turned each one 1/8-1/4 turn, and sprayed more. I then waited 10 or so minutes, and finished the extraction.
I personally think it's a better idea to spray them before you start trying to turn them, and mine all came out 100% unbroken with this method.
Old Dec 2, 2007 | 09:04 PM
  #77
ohboy44's Avatar
Whoa there buddy, I didn't mean to **** you off. I'm glad you got them out.
But I've changed more of these plugs then I can remember. And spraying them before you break them loose does no good, if you look at the plug design there is no way the Kroil can get past the seat where the plug tightens against the head.
Old Dec 2, 2007 | 09:18 PM
  #78
Bootleg837's Avatar
I would some what agree but what if the plug was all ready loose and all the blow-by lock the plug in well jest a what if
it sure cant hurt
Old Dec 3, 2007 | 12:13 AM
  #79
azmidget91's Avatar
id bet money on that this penetrating oil would help by spraying before hand.....besides its not like it could hurt and dude read the whole thread before posting
Old Dec 3, 2007 | 08:20 AM
  #80
Nolo's Avatar
No biggie. Just documented my plug change for anyone interested in doing the same thing. Hope it helps.
Old Dec 3, 2007 | 10:47 AM
  #81
Turd Furguson's Avatar
Can we see some pictures of what the plugs looked like after you pulled them all out?
Old Dec 3, 2007 | 10:50 AM
  #82
Go to his link, a couple of pics there. They didn't look all that bad.
Old Dec 3, 2007 | 11:14 AM
  #83
Nolo's Avatar
I'm making a trip to TX at the end of the month, and will be putting about 1500 miles on the truck. After I get home, I'm going to pull one of the Brisk plugs and see what it looks like. I'll post another thread with pics.
Old Dec 3, 2007 | 03:56 PM
  #84
Bootleg837's Avatar
Add it to this thread cause we are watching this one already
Old Dec 3, 2007 | 09:32 PM
  #85
freekyFX4's Avatar
Originally Posted by risupercrewman
I'm gonna hire you to do mine when its time for a change.........
Just make sure you hire him to do it BEFORE he passes the BAR exam.
Old Dec 3, 2007 | 09:37 PM
  #86
risupercrewman's Avatar
Your right! God only knows what he will charge if he passes........
Old Dec 5, 2007 | 04:17 PM
  #87
Nolo's Avatar
Well, looks like i'm having a really rough idle. (er... feels like it i mean).
I replaced the throttle position sensor, and it didn't fix anything. I tried to call Troyer Performance, and they are closed today. I'm thinking that my gap is too small on the Brisk plugs. I'm going to check to see if it is with Mike, and if so, will regap and reinstall. If it's the correct gap, I'm going to pull the plugs and stick the Autolites in.
Old Dec 5, 2007 | 04:35 PM
  #88
Keep us Posted!.............
Old Dec 5, 2007 | 06:26 PM
  #89
Irish FX4's Avatar
Are the Autolites a one piece design like the Brisk? Also are the double platinum?
Old Dec 5, 2007 | 07:06 PM
  #90
K1NGoftheRanch's Avatar
couldn't you just have ford replace them? that way if they broke they would b responsilbe right? also you change these at 100kmi? thanks and glad you got them all out...
