For ppl who did the rear window rattle TSB, question....
Old Nov 29, 2007 | 12:52 PM
Hawkz28's Avatar
Hi all,
I have a quick question about this. I have the squeek from the rear window, I DL the TSB and found that I need to do procedure B, which is easy.
My only question is, the exterior trim of the window goes all the way around the cab. Do I grease the entire exterior trim where it meets the paint or do I only do a certain section?? I'm not sure exactly where to grease this thing from the outside, only thing that makes sense to me is to lift the molding around the rear glass and grease all up underneath that....
Any help? Thanks
Old Nov 29, 2007 | 02:34 PM
ckforker's Avatar
I actually used silicone and let it dry before moving the window, it not, the grease will just smear I would think. The silicone did the trick for me.
Old Nov 29, 2007 | 03:05 PM
FX4 Matt's Avatar
Registered User
Mine will rattle when it is cold I just hit the open button for a sec and it makes it stop
Old Nov 29, 2007 | 03:16 PM
Big Slick's Avatar
can you buy the trim for procedure A? mine rattles and i'm sure the dealer would charge me to fix it since i'm over 35K.
