Bilstein 5100 Pics
Old Nov 8, 2007 | 03:20 PM
WhiteGTSofDeath's Avatar
Originally Posted by Tylus
can you get a pic of the upper control arm with the tire installed?
I'd like to see the clearance
Here you go.
Old Nov 8, 2007 | 03:23 PM
mc2912's Avatar
Originally Posted by ThumperMX113
Why is there a RCD sticker on there?
X2 wondering the same thing.
Old Nov 8, 2007 | 03:25 PM
JBMX928's Avatar
Graphics Contributor
nice truck n nice upgrades. love the mirrors!
Old Nov 8, 2007 | 03:31 PM
When I opened the UPS box, I saw the shocks with the part number one digit off and there were only two preload points on them. So I called the vendor I bought the stuff from.
He told me that RCD worked with Bilstein during the R&D of the shock. The part number on the box was a RCD part number. Hence the RCD sticker.
Old Nov 8, 2007 | 03:35 PM
ThumperMX113's Avatar
Wierd, mine didn't have any RCD sticker.
I know RCD does have their own Bilsteins for their 4.5"/6" lift kit though ..
Old Nov 12, 2007 | 04:21 PM
I have a couple pictures that I took from my cell phone with a dirty lens.
Here you go.
Old Nov 13, 2007 | 09:56 PM
05'ThumpinSTX's Avatar
Hey WhiteGTSofDeath where did u get ur mirrors from? I was thinkin about getting new mirrors (XLT/FX4/Lariat) but those look awsome!
Old Nov 13, 2007 | 10:41 PM
Ftruck05's Avatar
Those are the 08 F-150 towing mirrors.
Old Nov 14, 2007 | 10:58 AM
They came on my truck (Manufactured in July 2007)
I guess I got lucky...
Old Nov 14, 2007 | 11:04 AM
z2896's Avatar
I got mine off ebay for $350 and there is an RCD sticker too. The part number on the box goes not match Bilstein's website but these are the ones that lift the front two inches.
Old Nov 16, 2007 | 06:32 PM
jhartley's Avatar
Originally Posted by Jditta
You can you will just need a spring compressor.
Make shure you have a good compressor i used the ones from autozone and the all threads started bending so i had to have two sets of compressors to get the spring compressed to the two inch mark.
Old Nov 17, 2007 | 08:06 AM
Big Slick's Avatar
so this is an alternative to the autospring?
would they work in conjunction with a suspension lift down the line to give you a bit more height or is shock travel an issue?
Old Nov 17, 2007 | 04:06 PM
Yes it is.
They would work. Shock travel isn't an issue. The a-arms bind on the huge stock coil spring before you top/bottom them out.
Old Nov 17, 2007 | 06:33 PM
Big Slick's Avatar
Originally Posted by WhiteGTSofDeath
Yes it is.
thanks. for some reason, i like being able to adjust height via the coil over instead of using a spacer.
Old Nov 17, 2007 | 06:58 PM
dkstone05's Avatar
I just put an AS kit on a couple of months ago. But now I thinking I'm going to get these. It seems that the back end wants to hop around more since I put a higher load range tire on. I'm hoping the Bilstein help out a little.
