Multi shock system?
Old Oct 26, 2007 | 04:46 PM
KiCk aSs FX4's Avatar
Multi shock system?
Anyone seen any multishock system for our trucks?
Old Oct 26, 2007 | 04:51 PM
ThumperMX113's Avatar
Are you talking about for the front or rear?
Old Oct 26, 2007 | 05:02 PM
both...but mainly for the front.
Old Oct 26, 2007 | 05:08 PM
mSaLL150's Avatar
kinda tough to do with IFS right?
Old Oct 26, 2007 | 05:56 PM
extremeethan's Avatar
Yeah its called you have a coilover truck and have no need for 2 shocks because on 2.5 will handle anything you can throw at it.
https://www.f150online.com/forums/sh...d.php?t=304027
Old Oct 26, 2007 | 06:19 PM
what i really was looking for is something skinnier than my coilovers since they rub up against my spindle arm at certain angles. even in that forum with that crazy setup he still is pretty close to that arm. im sure if he cranked those coilovers a little more they would hit.
Old Oct 26, 2007 | 06:56 PM
Do you have upgraded coilovers now? if not get them they make a lot of room in your coilbucket as well as even at max droop or any trun they are small enough that the upper arm cant hit them.
Old Oct 26, 2007 | 07:45 PM
no i have stock coils with fabtech shocks. and a spacer. I believe upgraded coilovers would help but I wont get as much height out of them as I do with the spacer. Then i might have rubbing issues.
Old Oct 26, 2007 | 07:49 PM
You can get just as much out of them as you could with the fabtech shocks and a daystar. You can get 3 inches out of them, I dont recomend it because of angles but you could if you needed that much to clear
Old Oct 26, 2007 | 08:07 PM
hey extremeethan check your pms
Old Oct 26, 2007 | 09:18 PM
Josiah's Avatar
Dave, I might be willing to trade my used coilovers for your stock coils w/spacer + cash. Make an offer or something, I really might sell them as I'm eventually getting rid of the truck and I won't get more for having them on. I say eventually because I'm scared to throw anymore cash out the window at a new Superduty.
djh1121's Avatar
I'm thinking about get some aftermarket coil-overs for the same reason. I think I could clear these 37's with just a 2" spacer ( or coil-overs craked 2") and that would help this damn angles... What do you think Dave?
Old Oct 26, 2007 | 09:19 PM
djh1121's Avatar
Hey Josiah, hit me up if Dave doesn't want that deal.
Old Oct 27, 2007 | 12:55 AM
josiah check your pms
I have a spacer now and I clear them fine (only once i hit a bump while turning pretty hard and it rubbed a little when i hit it) the only thing i dont like is that the spindle arm hits the stock coil and that the suspension is so stiff. I think slightly cranked coilovers would be a better ride.
