HEX Code question?
Old Oct 14, 2007 | 02:37 PM
whitecrystal1's Avatar
HEX Code question?
How come Edge reads a longer number than what's on the firewall? The firewall shows 3 letters and one number. Edge reads this #RXCM5A6.HEX So would the HEX start at the X and read XCM5?
Old Oct 14, 2007 | 03:52 PM
Ftruck05's Avatar
The Hex the EDGE gives you isnt even complete. I thnk a full strategic code is one number longer than the edge's. This is just Fords way of grouping similar ECU's. Why they have so many I couldnt tell you.
Old Oct 14, 2007 | 05:34 PM
How do I find what the real (whole) code is now?
Old Oct 14, 2007 | 06:09 PM
MGDfan's Avatar
Hey - that procedure is in the Edge manual - what you are reading will be the strategy ( calibration) code.
The number on the PCM label on the firewall is the Box code. If you've been reflashed for any reason, then it's best to get extract the code from the PCM.
The first 5 characters are the 'family' - the last two are usually required for full custom tuning.
F150's sure do have a lot of these, every MY.....
Experts - take it away from here ....
Old Oct 14, 2007 | 06:23 PM
That's what I'm wondering I was reflashed. How to I extract the code. I only see the strategy code when The Edge booted up. Am I doing something wrong or not doing something I need too?
Old Oct 14, 2007 | 06:31 PM
MGDfan's Avatar
Good question, buddy - since I don't have one, I can't guide you through the procedure, but I'm sure there is a simple one for displaying strategy, anytime you need to....gotta be.
Someone conversant with this will be along shortly .....
Good luck.
Old Oct 15, 2007 | 11:38 AM
i.ride.suzuki's Avatar
Rxcm5a6 = Bnj0
Old Oct 15, 2007 | 12:30 PM
Originally Posted by i.ride.suzuki
Rxcm5a6 = Bnj0
Is there some trick to getting that info? I didn't see anything in my owners manual that showed how to get it.
Old Oct 15, 2007 | 12:55 PM
I viewed fords hex file in plain text to get that.
Old Oct 15, 2007 | 01:01 PM
MGDfan's Avatar
LMAO
I think he means using an Edge, PRP-boy !
White - lemme download the dang manual (again, lol) and see if I can find the appropriate section for ya, as it appears all the other Edge ****'s don't wanna help here
Back in a sec ...
OK - I'm back - Diagnostic Menu ( page 18,19), from the Main menu - Version Info - will display your HEX code.
bubba
Old Oct 15, 2007 | 01:05 PM
LMAO
Back in a sec ...
Haha, i am serious....
EPROM PART NO. > 1472K ;XXXXXXXXXXX COPYRIGHT CALENDAR YR > 2006 APPLICATION > N/A FILE TYPE > BOAK FILE NAME > RXCM5A6.HEX RELEASE DATE > Mon Jun 26 15:25:22 2006 MODULE TYPE > MN2-L352C VEHICLE CALIBRATION > 5F613E0A16 VEHICLE APPLICATION > P221 ENGINE SIZE > 5.4L PRODUCTION MODULE PART NUMBER > 5U7A-12A650-EBA OMIT FROM SERVICE TOOL FLASH>0x00000000 ^ 0x0000FFFE FLASH INDICATOR> 1 FLASH ERASE SECTORS> 0xAA FILE CHECKSUM>0x08DE CATCHWORD > BNJ0 WERS NOTICE > APED E11897909-000 DESIGN TRANSMITTAL > N/A CAL ID > 10222;FABF LAST DATA ADDRESS > 005AED67 COMMENTS > FOR PRODUCTION USE ONLY. RELEASED BY > RBROWN9 DIV/DEPT > TEL > $ :  ú: ` p: ~ÌCopyright (C) Ford Motor Comî: @ pany 1993,1994,1995,1996,1997,19J: ` 98,1999,2000
