Added 20's & 33's now I need more OD holding power
2006, 4.6, 3.55, scab, 4x4 w towing package. Went from factory 17's and 31's to a much wider larger 33" tire and 20" rim. Now the truck doesnt want to hold overdrive on any of the hills it was able to before. Will a tuner be enough to make it as it was before or do I have to suck it up and get gears?
My suggestion is to get a VMP Tuned Xcal2 and than if thats not enough get the gears. The tuner will come in handy anyways when you make gear changes as well as to correct your speedometer.
www.VMPTUNING.com
www.VMPTUNING.com
that seems very weird. going up only 2" shouldn't have made that big of an effect.
with your motor, it would be most likely a 4.10 gearset for you. you'd get some nice performance and keep the highway RPM's down
^^^ Not what I'd call an over-abundance of low-end torque to begin with.
Further degrade that with a combo of a 0.70 OD ratio +2" + add mass at wheel circumfernce = what he's experiencing.
Originally Posted by ThumperMX113
He's got a very sensitive assmeter, it can pick up very slight changes in performance.
Seriously though, he's got a 4.6L and 3.55s. It's not a good combination for a bigger wheel/tire package.
Since you have an 8.8 rear, a 4.30 gear is an option. IMHO thats a good gear for a 33 inch tire. Now I am only going by the math, not the actual experience. I am too cheap to buy the tires and gears up to this point.
I switched to 33's "285/70/17" recently and have the same thing going on. I wanted 3.55 and 4.6 for better hwy mpg. When I purchsed I had no intentions of running anything over a 265/70/17, but that has now changed. Killed my performance and lost 3mpg from the crappy stockers.
I am not shocked in the least. Hind site is I should have just gotten the 5.4, but I had my head in a hole when I bought this one.
If ford could ever get my ride issues straightened out, I planned on paying them to re-calibrate the computer. Have heard this could help a little,bit but is no replacement for torque.
Good luck.
On a side note, a guy I work with just turned 300k on his 4.6 and auto tranny. Makes me happy to hear. The best part is he does little to no maint.
Good luck.
