Cruise Control Problem, Leak in rear of cab Solved!
Old Oct 7, 2007 | 12:23 AM
Polsort's Avatar
Post Cruise Control Problem, Leak in rear of cab Solved!
I am new to this...I have a 2004 FX4 that had a few problems, and just got it back today from the dealer. My cruise control stopped working one day, and it would not come on after that. I also had water leaking in the rear of my super cab from rain or dew in the morning. I finally took it to the dealer and they told me that the shift interlock was defective and that it would not allow my cruise control to engage. They put a new one in and it works again. The problem with my water leak was caused by a leaky third brake light. They replaced that and I am hoping it solves the problem. Wanted to post this in case anyone else was having the same problems as I was. It ended up being 450 dollars to fix so if your having these same issues and if you can fix it yourself it would be cheaper. Also, believe it or not I am almost to the 150000 mile club and the truck has been pretty good since I bought it new. So take care of it and it will take care of you, and this is coming from a die hard chevy fan, but my old silverado was not better than this ford so if you can't be em join em!! I am still not giving up my Camaro though : ) When I have more issues and solutions I will post them.
Old Oct 7, 2007 | 03:03 AM
vtn98's Avatar
Question. DId you change your spark plugs at 100K per the maintenance guide? Any issues?
Old Oct 7, 2007 | 11:36 AM
Tylus's Avatar
150k, wow that's amazing.
ditto the above question?
Old Oct 7, 2007 | 01:04 PM
Polsort's Avatar
I took it into the dealer around 105,000 miles to have the maintenance done, and yes they changed out the spark plugs also. I lived an hour and a half away from work until a year ago, that is the cause of the high miles. The truck and leather interior still looks new besides some wrinkles in the seat because of the leather. I should post some pics, the truck is mostly stock though. It has 148000 miles on it now. I bought in the fall of 2003 so it was one of the first built with the new bodystyle. No major problems though.
Old Oct 7, 2007 | 01:55 PM
Tylus's Avatar
It's nice to see people who have these trucks and have no major problems.
hope you continue to have good luck with it
Old Oct 9, 2007 | 09:38 PM
NeFX4's Avatar
If you don't mind me asking, how much did the shift interlock replacement set you back? I am pretty sure that is the problem I am having with mine...curious to see how much it is going to cost me. Thanks
Old Oct 9, 2007 | 09:51 PM
JesseRohr's Avatar
whats the deal with all the spark plug talk i have been seeing on here?
