Need help w/keyless entry code
Old Sep 24, 2007 | 06:02 PM
labbiegirl's Avatar
Question Need help w/keyless entry code
Just purchased a 2004 F150 w/keyless entry. Unfortunately, the previous owner never left the 5 digit code to use the keyless entry. Does anyone know where to find it on this vehicle. Your assistance is much appreciated.
Old Sep 24, 2007 | 06:38 PM
dkstone05's Avatar
I had a card that had the number on it that came in the owners manual zip up folder. I would check that first. If not I "think" it might be behind the backseat on a box that is mounted on the back of the cab. Take a look in the owners manual I think it says something in it what to do if you forget the code. Someone should chime in with a definite answer where the code is located though.
By the way welcome to the site.
Old Sep 24, 2007 | 06:40 PM
dkstone05's Avatar
You can also try doing a search, I'm sure this has been asked before.
Old Sep 24, 2007 | 06:41 PM
05RedFX4's Avatar
There is a sticker on the Body Security Module that has the 5 digit code you need. The BSM is on the back wall of the cab, behind the back seat on the drivers side.
Old Sep 24, 2007 | 07:38 PM
07screw's Avatar
My last truck i had to have the ford dealer scan it and then the master code would show up
i did not know it was located in the truck
Old Sep 24, 2007 | 08:38 PM
labbiegirl's Avatar
keyless entry code
Thank you everyone for your posts. After fighting with the back seat, we finally found the code. You can't imagine the relief! We looked high and low in that truck. Thanks again!
Old Sep 24, 2007 | 09:00 PM
05RedFX4's Avatar
Now that you have the original code, look in your owners manual and there is instructions on how to program your own 5 digit code.
And welcome to the site, now you need to post pics of your truck and tell us what you have.
Old Sep 25, 2007 | 01:19 AM
Grubrunner's Avatar
Was it a bitch to get to?
Old Sep 25, 2007 | 04:52 PM
labbiegirl's Avatar
keyless entry
It took some time to figure out how to get the seat out. Once the seat was out, it took all of 2 minutes to find the code. I'll get pics on as soon as I take some. Just got the truck saturday and I've been so busy looking for that darn code, I haven't had time to do anything else.
Old Dec 25, 2007 | 05:21 PM
ibgolfr's Avatar
entry security code
labbiegirl
whatever happened to the pictures you were going to post regarding removing rear seat to get to entry secuity number...I need to take a peek at my numbers and wondered if you could share how you get the seat removed.
Old Dec 26, 2007 | 09:35 AM
ibgolfr's Avatar
the code is behind the back seat on the passenger side...remove back seat instruction
take a look here to see how to remove the rear seat of your 2004 F150 and there in rests the place the secret entry code rests.
http://www.ford-trucks.com/article/i...2008_F150.html
