Oil pan gasket replacement at 48k miles
My 2004 Screw has been leaking a little oil for a couple weeks. I change the oil and filter so I know it wasn't cross threaded. Took it into a garage I trust and they said the oil pan gasket is leaking.
Cost to replace gasket and oil change is $525. The gasket is only ~$25, and the rest labor. They have to loosen the engine mounts and jack it up to get the oil pan out.
Anyone else have this problem? Is this a fair price?
TIA
TIA
This is a very common occurence with the 5.4 3v's.
I know several here that it has effected, including myself. However mine did not start leaking until I switched to Mobil 1 @ 10,000 miles. ( I am not rapping Mobil 1). Several have leaked from the oil filter mounting unit also.You can do it yourself but you better have the necessary equipment to do so.
I was just in sticker shock with that quote, but from what I hear its allot of labor.
Changing the gasket on the oil pan is a PITA. You have to lift the motor up a good 6-8" becuase you not only have to get the pan out around the front K member but you also need room to manuver it out around the oil pump pick up tube which sits about 1/2" above the lowest part of the sumped end of the pan.
