why would this happen???
If you have the 5.4, you need to do a search on the subject and get educated about the plugs for the 5.4, 3v engine. If it's a 4.6, no biggie. If it is the 5.4, there is only Motorcraft and Autolite, same manufacturer.
This sounds like my cousin's situation about a year ago. He never modded his truck, and the maintainance records were top notch. He wanted to get about 12 years of service out of this truck, and it never gave him any problems until the mileage dropped about 2 mpg (he reported 18.2 to about 16). He tried different gas, filters, and tire pressure, but never broke 17 for awhile. The truck had about 65K on the clock, so we decided to change the plugs. He wanted to wait until the recommended 100K mark, but he did not know what else to do. The plugs looked really bad and took awhile to get out safely. In the end, the truck got 18.5 after changing the plugs. That's when I decided that Ford's recommended plug change was a load of crap.
This sounds like a perfect time to try the plugs. With a little research here and other places, you will want to be careful when doing this job. Good Luck.
It's even a bigger load of crap now - with the new, advanced, self-seizing plug design in the 3V's LOL!
Bosch designed those O2's - and they say 30-50k. Vetoed by Ford, of course so as not to upset the TCO applecart...
Originally Posted by Grubrunner
Nothing you've listed, individually, would drop his economy 3MPG on highway runs.
Combined is a different story.
PS: You can rule out "mods" as he clearly stated in the opening thread that he has none.
Thanks for taking the time from your busy schedule to set that record straight
Originally Posted by SmokeyBear
Air filter obstruction maybe, check and see if you've picked up a leaf or something in your air box??
Originally Posted by scott1981
Temp, tire pressure, roads trevdeled, time idling, brand of gas, A/c on, mods? All these can play role
Pfffttt...
Ok Grub
Care to show me where I said 1 of these items were responsible for his problem. I said they can play a role and I stand behind that.
Ok Grub
That's why I threw the word "individually" in my reply to you.
you might could attribute the change in mpg so drastic to bad math...how do you figure your mpg??? odo reading only??? onboard computer??? how many gallons put in tank???? was the truck flat or on incline while filling??? many variables....and the last best is how long has the drop been noticed???? just one tank??? it could be a mechanical or software problem indeed, but it could be a simple one of just math.
i really dont think the things listed here can drastically reduce your mpg so rapidly, im assuming it was a sudden drop, or are we talking about a loss of 3 mpg over some time, i believe in preventative maintenance, so even its not time, i would replace the fuel filter 10 bucks at advance auto for MC. change plugs to autolite ht-1... good luck, 90 bucks total from pepboys, oil and oil filter your choice...
does the truck feel more sluggish? rpms out of whack? pinging or other engine noise? hard starting? rough idle?
