2 Wheel Drive
Mine is 2wd and sits just as high as 4wd's. I just put 4wd coilovers in instead of the smaller 2wd coilovers. Works great. I go just about everywhere 2wd's go (except in the dunes) in glamis because I know how to drive. So lift your truck if you want and dont worry about what people like Suzuki say. Its your truck do what YOU want.
Originally Posted by Bartak1
Lift it and put a locker in it if it doenst have LS already. You would be suprised what you can do if you know how to drive it right.
I love my truck. It is a 2wd w/ 6inch procomp kit 5inch fabtech rear block, 20 inch KMC Hoss wheels, 35inch nitto terra grapplers, edge programmer and 456 gears. I would highly reccommend the programmer and gears if you go bigger on tires. I got all of that done at one time for $6000 parts and install. Hope this helps. My pics arent of it w/ the 5inch fabtech block I did get that done later. It also makes a huge huge difference on 2wd lifts and I highly reccommend that also.
I've been on trails in my old truck in 2hi, whizzing right by guys in 4low....
2wd lift
I have a 05 screw and put on 2.5 AS lift in front and 2" blocks and ubolts from a 4wd in back. Sits about a 1" higher in front than stock 4wd. 285-70-17 nitto terra grapplers. Looks like a 4wd for only $250.00.
Originally Posted by jawjaboi
It must have not sucked that bad. You were willing to "lower your standards" and buy a 2wd just because you couldn't "afford" a 4wd. That's a lame excuse. Why didn't you just buy a "cheaper" 4wd like a Tacoma or Ranger or something you could "afford". And by the way, my "2wd" KR probably cost more than your "4wd" FX4.....
A small lift, A/T tires, and a limited slip diff can get you in many places that a stocker won't. Your truck will take a bit more of a beating from the inertia that is needed to get through and/or over things but it will get the job done.
My last truck was a 98 2x4 and I took it just about anywhere I wanted to go. Never got it stuck. (although really close a few times) even on a few trails marked 4x4 only.
