Dynomax bullets
Old Aug 30, 2007 | 08:12 AM
jdoggfx4's Avatar
Dynomax bullets
I'm fixing to order one of these but I want to make sure that it is going to be worth it. (ie better performance then my flowmaster 40 series)
Any info would be great. I would like order this am
Specs on truck
K&N Cold air
Edge Lvl 2
5.4L
Fx4 Scab
Running duels with a SI/DO
Stock wheels and tires for right now.
Lift and gears later on.
Old Aug 30, 2007 | 11:16 AM
ThumperMX113's Avatar
I don't have one but I'm ordering some soon.
Old Aug 30, 2007 | 01:49 PM
dly97's Avatar
I have one on my 4.6L, it sounds great. It has more of an aggressive performance sound to it. It should sound really sweet on a 5.4L with a intake and a tuner. As far as picking up any performance over a flowmaster, I don't know. It is a straight through design, so I believe that's supposed to be a little better than the baffled flowmaster. Probably the sound will be the only real difference.
Old Aug 30, 2007 | 03:00 PM
jdoggfx4's Avatar
I just ordered mine should be here in a couple days. I'll give ya'll a report once I get it installed.
Old Aug 30, 2007 | 04:37 PM
mSaLL150's Avatar
i was looking into these things too, but my currently setup is a SI/DO and they only make SI/SO for the bullets and i want to keep my dual tips. i found the dynomax ultra flow welded muffler that is SI/DO and the exact same size as my super44 so it would fit perfectly as a replacement, but i dont think its going to give me the same loud sound as the flowmaster, and i dont want to lose any sound with a muffler swap. Will it not be as loud??
Could i run the bullet SI/SO then have a Y-pipe right after the muffler into my dual tips? or would that give me bad airflow?? (the Y-pipe would also have to go from a single 3" to dual 2.5", is it possible??)
Old Aug 30, 2007 | 04:40 PM
I measured my exhaust tubing which came out to be 7.25" and if you divide that by 3.14" you get 2.3 so I'm guessing I've got 2.25" tubing. Its supposed to be 2.25" but I'd hate to order my stuff and than find out its wrong!
What do you guys think?
Old Aug 30, 2007 | 04:45 PM
mSaLL150's Avatar
2.25. your measurement of 7.25 isnt exact, and 3.14 is a rounded number as well, if you used more accurate calculations then you would get 2.25.
Old Aug 30, 2007 | 05:11 PM
bud8817's Avatar
every time i listen to my exhaust i get a hard on.... am i aloud to say that.... anyways. i am extremely happy with mine much more power that i could ever expect and sounds amazing.
im actually looking to do true duals with these just havent had the time to do it.
Old Aug 30, 2007 | 07:11 PM
Josiah's Avatar
Get a sound clip will ya?
Old Aug 30, 2007 | 07:28 PM
weazel's Avatar
Registered User
Exclamation Video Clips!
Here a couple vids of my set up! I think its pretty darn loud! lol..
Old Aug 30, 2007 | 07:32 PM
weazel's Avatar
Registered User
the SI/SO into a y pipe would flow better then you SI/DO Flow master!
Old Aug 30, 2007 | 08:06 PM
jdoggfx4's Avatar
thats what i was thinking about doing
Old Aug 30, 2007 | 08:48 PM
Jwool15's Avatar
I switched from a flowmaster 40 and the hp difference was really noticible. Its way more peepy and the sound is amazing. I also recomend dumping it.
Weazel i thought you had a loudmouth?
Old Aug 30, 2007 | 08:51 PM
weazel's Avatar
Registered User
i do, just showing for comparison
Old Aug 31, 2007 | 08:29 AM
jdoggfx4's Avatar
So you think I should get rid of my duels and just dump it under the truck?
I thought about that but when I go off-road I like to be able to see where the exhust is if I'm in water and with it dumped under the truck that would not be a option.
