Dynomax bullets
Originally Posted by Jwool15
See Patman after all this harping on buying a dynomax people are starting to catch on. I know when yall get them on you will be in love from the first start up. Beware though it takes about a tank of gas to break in. The farther you drive obviously the more its going to break in. It only sounds better with time inless your pat and it sounds like theres a dead squirrel bouncing around in there.
We could be the Mike Troyers of Dynomax
I'll let you know what my results are.
Thanks John
nah eventually ill be doing true duals 2.5 with X pipe dumped. Ive just got soooo much im trying to do in the next couple of months, that its hard to change something that is "functional"
Well I just got back from getting my bullet put on! I must say that it sounds 10 times better then my flowmaster did and the drone was cut 75%. I decided to play with fire and update my edge to see if that will help cut some moredrone out... We shall see.
All in all this muffler was worth the money the **** dyno seems to think there is a little more low end.
I put on a Dynomax Super Turbo SI/SO in March. I love how it sounds but I'm thinking of dumping it. Here is a link to a sound clip, I think there might be a pic or 2 in my gallery
https://www.f150online.com/forums/sh...ht=Sound+clips
No, I cant even tell unless the windows are down. I get some drone around 1700-2000 in OD but thats about it. That sound clip is pretty old, it sounds a little deeper now I'll try to update that $#!+!
Originally Posted by AirborneRacer
Jegs list them as 289-24215 for 2.50". I assume its same,same as listed above? So if I want to go SI/SO dumped the 2.50" would be prefered?
