LED tails
Old Aug 31, 2007 | 02:45 AM
Josh M's Avatar
Do you have to cut the stock wiring harness off to install L.E.D. tail lights? I mean the whole things, not just the bulbs.
Old Aug 31, 2007 | 04:30 AM
04procompLARIAT's Avatar
NO...its purely plug and play. Just unplug the stock lights and plug the LED's in.
Old Sep 6, 2007 | 11:26 AM
FORDMAN0781's Avatar
Does every truck require a load resistor? I rarely use cruise control so the cruise disengaging is not a real big deal for me. I would like to install these lights but I suck at electrical work if I needed to put the resistor in.
Sal
Old Sep 6, 2007 | 11:44 AM
ford2004F150's Avatar
I replaced my bulbs with LEDs all the way around the truck. I have NO issue with the cruise control cutting out after a signal.
Just an FYI.
Old Sep 6, 2007 | 11:25 PM
fireman137's Avatar
Sal
You will get the hyperblink problem if you don't use either load resistors or replace the flasher under the dash.
