Pinion seal
Old Aug 22, 2007 | 10:08 PM
theanimal's Avatar
Pinion seal
Does anyone know how much is invovled in changing the pininon seal? Is it a matter of just dropping the drive shaft and pulling the pinion out, changing the seal and putting it back together or will the pinion have to be pressed out of the pinion support? I have a tiny leak from this area and would like to fix it.
Thanks guys
Old Aug 22, 2007 | 10:13 PM
last5oh_302's Avatar
You have a 2005? You should have warranty left. Why not let a dealer worry about it?
I know that wasn't much help if you want to do it yourself, but you just received my anyway.
Old Aug 22, 2007 | 10:22 PM
ThumperMX113's Avatar
I'm not exactly sure but you probally want to get a new driveshaft otherwise its just going to happen again. .
. . probally because hes sitting on 40s and the dealer won't warranty they know was caused by the insane amount of lift hes got.
Old Aug 22, 2007 | 10:23 PM
Ftruck05's Avatar
Have you seen his truck??? I doubt any dealer would touch that thing with a 10 foot pole. If it were my truck I wouldnt let them. Oh yeah, my 05 just rolled 58,000 yesterday. Warranties are for Sally's and Nancy's
Old Aug 22, 2007 | 10:28 PM
kalebarellano's Avatar
Were did you get your gears installed? I would take it to them. I bet they left your original pinon seal in. Thats what 4-wheel parts did with mine, and it leaked so they replaced it. There is no need to replace the driveshaft. I think you may have to pull your carrier/gears out, disconnect the driveshaft, knock the pinion out, replace the seal, and put it together.
Old Aug 22, 2007 | 10:29 PM
theanimal's Avatar
Yeah these are just the kind of problems that I am going to have to deal with. I knew all of this before I did anything to the truck.
I know it will be an ongoing problem but if its something I can do really cheap myself, I dont mind doing it once a year or so rather than but a whole new drive shaft.
So if anyone has any knowledge on this, let me know whats up
Old Aug 22, 2007 | 10:30 PM
theanimal's Avatar
4 wheel parts did the swap. I may take it back to them and see what they say. Thanks for the input
Old Aug 22, 2007 | 10:33 PM
These two have a lot of issues with their trucks?
No need to replace the driveshaft? Alright. I've heard it all. .
Old Aug 22, 2007 | 10:35 PM
Josiah's Avatar
Mine is leaking as well, you have much vibration @ highway speeds?
Old Aug 22, 2007 | 11:19 PM
Quintin's Avatar
The proper method of replacing your pinion seal involves tearing the axle down, popping the old seal out, replacing the pinion crush sleeve and putting it all back together. Reset the pinion bearing preload to spec and drive on. This is how it's supposed to be done, since removing the nut that holds the pinion flange on changes the bearing preload. The bearing preload is set with a crushable spacer, so naturally once it's crushed (like when the axle is assembled from the factory, or whenever the ring and pinion are replaced), there ain't no going back.
The ghetto fabulous method of replacing pinion seals goes something like, pull the flange off, pop the old seal out, hammer the new seal in, reinstall the flange and hope you got the bearing preload set right. I've done them this way, sometimes I get them right, most times I don't. It's hard to get an accurate "before" reading for pinion bearing preload this way, since the drag from the axles and carrier are affecting whatever reading you get (pinion bearing preload is checked with an inch/lbs torque wrench on the pinion nut...however many in/lbs it takes to rotate the pinion).
If in doubt, get someone in the know to replace your pinion seal. At best, if you get the bearing preload wrong, you'll just get a little gear whine. At worst, you'll destroy the pinion bearings and/or pinion gear.
Old Aug 22, 2007 | 11:26 PM
I didn't have to replace mine when my seal leaked.
Old Aug 22, 2007 | 11:28 PM
Thats not my point. Do you realize how much your tailshaft is coming out of the transfer case? It's not a very good idea, especially if you plan on offroading. A driveshaft falling out isn't a fun thing.
cdnance's Avatar
i have a 97 f150 and me and a buddy replaced one in about 45 min. the only reason it took that long was because i had to run to autozone and get some gear oil. i may have gotten lucky, but it has been in for about 12k miles and there hasnt been any problems. but i would listen to quintin just incase. if you are a do-it yourselfer, then to hell with it. my seal cost 9 bucks i think. but i already had a puller and all the tools. so it is up to you. you can take a chance with the bearing or take it in. just my experience. by the way i am NO and i mean NO pro mech.
Old Aug 22, 2007 | 11:38 PM
zx12-iowa's Avatar
pinion on my last truck replaced - was 110 at the dealer. part was like 10 - rest labor
