Lifted trucks.. How does it pull?
Old Aug 23, 2007 | 09:40 PM
KiCk aSs FX4's Avatar
I know they are 20s and 37s. Im pretty sure its a 6" and what looks like just a front 2" spacer. You can tell by the extreme angles on that upper A-arm and the red looking spacer above the strut
Old Aug 23, 2007 | 10:17 PM
ThumperMX113's Avatar
It's a 6" Fabtech + 2.5" Daystar spacer. I'm not sure about the rear lift but its sitting on 20s wrapped in 37s.
Old Aug 24, 2007 | 12:08 AM
lockemn's Avatar
i am wanting to run 37's with 6" and stacked leveling kit thinkin about 18x9 rockstars or monsters 4.5" BS will i rub?
Old Aug 27, 2007 | 12:20 AM
lockemn's Avatar
thanks for the replys fellas.
Old Aug 27, 2007 | 05:24 AM
I have a similar setup and I dont rub
Old Aug 27, 2007 | 11:06 AM
acris24's Avatar
im running 37's with the help of a 3in body lift and some add-a-leafs in the rear to level it out, no rubbing here ill update my pics in my gallery as i have done a few changes
Old Aug 27, 2007 | 03:57 PM
torturekilla's Avatar
at 65 im rocking 2200rpm and at 75 im mastering 3000k rpm ftw lol :P
but this will all change when i stuff some 37s
Old Aug 27, 2007 | 05:23 PM
i.ride.suzuki's Avatar
At least make it believable if your truck has imaginary gears....
Old Aug 27, 2007 | 05:25 PM
scott1981's Avatar
Originally Posted by Texan Aviator
Trucks with 37s.. I'm going to be using my truck to pull a few arctic cat 650 quads to go riding on the weekends. How much of a pain is this going to be? I'm going to regear but probably not right off the bat. Maybe after a month or so of the lift and tires. But without re-gearing, then after re-gearing how much of a pain will it be to pull a 12' utility trailer with some quads on it?
And to combine in one post.... Will 38/13.5/20s or maybe even 15.5s fit on a 8" rize?
Thanks!
Hey Tex where do ya mostly ride?
Old Aug 27, 2007 | 06:03 PM
im being serious........ im running 32 inch tires..............
Old Aug 27, 2007 | 06:15 PM
extremeethan's Avatar
I calc. 2514 at 75 and 2179 at 65.
A 800 rpm window for 10mph seems like a lot
Old Aug 27, 2007 | 06:39 PM
Lol i had 4.56 on the stock FX4s, i know what it feels like. I also know the stock programming sucks with a gear ratio like that and stock tires. You need a custom tune* to modify the shift points (not rpm). You can add ALOT more room for 'later' kickdowns.
Old Aug 27, 2007 | 09:10 PM
37 + 4.88s
60 - 1800 rpms
70 - 2130 rpms
Old Aug 28, 2007 | 11:06 PM
lockemn's Avatar
kick *** how is the ride with that aal?
Old Aug 29, 2007 | 02:58 AM
Its a little stiffer but not too bad. On the road it feels fine. Id say a little more response from the road but I cant even really notice it. I notice the stiffness at most when I hit speed bumps.
