3rd Brake Light Leak Club
Old Dec 26, 2007 | 06:09 PM
RUSS04's Avatar
Originally Posted by Big Slick
can't think of anything besides the RTV. it's pretty simple in concept. i mean, the only thing sealing the holes in the cab roof is the foam gasket on the light. you can either
a) seal the holes up individually (i'm not sure that's even possible given the size of the hole where the harness comes through)
b) try to make your own gasket out of weather stripping commonly found at home improvement stores
or
c) run a bead of silicone around the gasket and call it a day.
A is probably too hard to do to make it worth the time, B probably wouldn't be that easy either since you'll have a seam to deal with that could leak. so C it is. i know RTV seams like a bubble gum and duct tape cure on your $40K truck, but it's better than having a leak.
Dont forget the small rubber rings that fit on the screws that hold the 3rd brake lite in place When i bought my hella tail and brake lite kit the rubber washers were included with the brake lite
