35-inch spare finally done
Old Aug 14, 2007 | 05:51 PM
BlackDawg's Avatar
This may be general knowledge for those running 35-inch tires but if not fyi you can mount a 35-inch spare in the stock location. After much debate I decided to buy a cheap (relatively anyway) 17-inch wheel and mounted a 315/70 Goodyear AT on it. So today I had some time for the moment of truth. After removing the back section of the Magnaflow it fit with not a hair to spare on the sides. The rear of it comes within a half inch of the hitch but it fits. In front it's 3 1/4-inch to the diff cover which I think is plenty for clearance or heat issues but would like to hear your thoughts on that. I plan on the mag-hytec cover anyway so that should help. As mentioned, I had to remove the back section of the Magna and I can't see getting any exhaust routed back there now but I had planned to exit out behind the rear passenger door if this fit anyway. Sorry some of the pics show the mess but I was trying to show the tire profile so you could see clearance.
Old Aug 14, 2007 | 05:52 PM
BlackDawg's Avatar
Dang the pics are small. Go to my album for the full size unless someone can post them bigger.
Old Aug 14, 2007 | 05:58 PM
ROBFX4's Avatar
Just like pie =)
Old Aug 14, 2007 | 06:06 PM
charlie101's Avatar
Thanks for the info!
Old Aug 14, 2007 | 06:11 PM
FoMoCoFan17's Avatar
Damn, if only they made 35" Krawler for a 17" rim. That would look so bad a$$ under there. Worthless, but still.
I need to do this. Wonder if my tire guy has a used 35 layin around
