Ac clutch bolt help
Old Aug 12, 2007 | 01:14 PM
donniep3's Avatar
Ac clutch bolt help
I had my ac quit on me today!! When I made it home I started trouble shooting and found that the outer part of the clutch fell off. I lucked out that it did not fall off while on my way back home. The only thing is that the bolt was no where to be found. If anyone knows what size, grade, and length could you please post the info.
Old Aug 14, 2007 | 05:55 AM
donniep3's Avatar
Problem solved
Old Oct 8, 2007 | 04:25 PM
gregerm's Avatar
what did you end up doing mine just did the same thing. Luckily I found the outer part of the ac clutch laying on the frame. are there any springs or shims that go in there also?
Old Oct 8, 2007 | 05:42 PM
gregerm's Avatar
ok 6mm bolt and washer for a shim. $1 at the home depot. Problem solved
Old Oct 9, 2007 | 05:06 AM
donniep3's Avatar
Dont forget to put locktite on it.
Old Nov 10, 2007 | 01:14 PM
foresterjohn's Avatar
happened to me too. What was the approximate bolt length?
Old Nov 10, 2007 | 09:25 PM
6mm 1.0 x 20 fit fine. thanks for the help
