led bulbs causing cruise control problem
Old Aug 5, 2007 | 09:20 PM
fireman137's Avatar
A few days ago my order arrived and I switched out almost every bulb in my 06 screw with led's. Instead of buying load balancers I replaced the flasher with a LED-compatible one. I was driving on the highway a couple days ago and was using the cruise control. When I put on my turn signal to change lanes the cruise control cut off like I had hit the brakes. I switched out one led at a time to see if it was a specific bulb with no luck. I tried different flashers too. Any ideas?
Old Aug 5, 2007 | 09:34 PM
Bootleg837's Avatar
when I plug my trailer in the same thing happens ???
Any help
Old Aug 5, 2007 | 10:13 PM
Impact9's Avatar
It don't make any sense why it would do that for changing out the bulbs for LED's. I'd suspect other things and the LED swap could just be a coincidence.
Old Aug 5, 2007 | 11:02 PM
fireman137's Avatar
I put the regular filament bulbs back in and the problem is gone, so it's def. related to the led bulbs. I just can't figure out how.....
