Straightening steering wheel
Old Jul 20, 2007 | 05:09 PM
BlackDawg's Avatar
Can anyone tell me how to straighten my steering wheel? It's slightly off center and really annoying. Is it a do it yourself thing or should I just take it to the shop? I traced the steering shafts to the steering gear, removed the nut at the bottom and turned the wheel straight but when I buttoned it back up the dang wheel was right back off center.
Old Jul 20, 2007 | 05:12 PM
KSUWildcat's Avatar
It's not your steering wheel that's off, it's your front wheels that are mis-aligned. Take it to a alignment shop and get the front end straightened out. ~$65.
Old Jul 20, 2007 | 05:13 PM
freekyFX4's Avatar
You will need to have it aligned at a shop. When you get the alignment, tell them that the wheel is not straight.
Old Jul 20, 2007 | 05:29 PM
i.ride.suzuki's Avatar
Don't listen to these fools, adjust the tie-rods (in equal turns). I will be doing mine tonight as my truck tracks straight but the wheel is off-center.
Old Jul 20, 2007 | 05:39 PM
KSUWildcat's Avatar
Some "fools" rest easier knowing it's done right and straighter than they probably could have done.
Old Jul 20, 2007 | 09:39 PM
Tbird69's Avatar
Don't listen to this fool, take it to the pros. You can adjust the tie rods to get the wheel straight but end up with a slight toe in/out that will wear the tires in a hurry. The only way to do it properly is to use the right equipment that will make sure everything stays in spec.
Old Jul 21, 2007 | 12:50 AM
BlackDawg's Avatar
Thanks for the replies. It's probably best if I keep the wrenches out of my hands for this type of thing.
