larger tire for stock 18" rims and no lift
Originally Posted by N901
It's a 4X4
Any bigger than a 295 and you'll definitely need a leveling kit.
Yes, it is on the lower A-arm. Actually it only does it when I'm turning at ABSOLUTE full lock to the right. I dont understand why, but it doesn't do it at full lock to the left. In most cases the rub is avoidable and it has not been a problem for me. Would recommend this setup to anyone.
305x65x18 here. No rubbing at all noticed, have the 2" AS so not sure with stock height. Noticed a definate performance hit over the stock 275x65x18 Wranglers though. Only thing is I wish I had gone with the 325x65x18. I will when I replace the 305's. imo-these tires make truck look great. ride is not bad either when you get used to it, I had mine roadforced.
