Can you drive a 4X4 F-150 w/o the front axle installed?
Thanks Ethan. I think you're right.
And I agree about the road dirt/debris getting into there from the backside if the axle wasn't there, so I probably shouldn't do it.
Only reason I was asking is because I'm going to install the lift over the weekend (this weekend) and the axle shop isn't open. Then the following week the guy I know who is going to install the gears for free will be on vacation. Looks like I should just wait until the following weekend to install the lift.
Thanks again.
Thanks again.
It actually looks like a design very similar to my wife's '02 Explorer.
Her's is a 4x2, but there's a splined hole in the hub for a 4x4 axle - they use the same hub for both. There's a seal to keep dirt out of the bearings, but the splined hole is wide open all the time, because all it does is pass through the hub to the backside of the wheel. The bearings are sealed seperately.
So if it is like her Explorer, except for rust on the splines if you leave it exposed too long, I can't see where anything should be a problem.
If you have a 4x4 then DO NOT DO IT !!
I broke my front differential in my Chevy Blazer this past winter going deer hunting. I had to drive it 2 miles with 3-wheel drive as I busted the front left halfshaft in two.
I got out the differential and put everything back together to drive it down the road a little ways so that a tow truck could come and get it. I drove no more than 1/4 mile with no differential and it destroyed one hub. All the pressure to hold the tires on came down on the ball joints. The ball joints helf up but the hub come apart and the bearings were exposed.
Originally Posted by Nates06SCab
I don't pretend to be an expert on 4x4 (but I'm no dummy), but CV axles don't suspend hubs and/or spindles. I could see how running just one axle (if you kept it in 4x4) could potentially wreck a differential. Maybe I'm confused or I'm reading your story wrong.
Yes driving in 4x4 with just 3-wheels activated can trash a differential. I already knew mine was trashed after noting it broke the support brackets of the differential that connects to the frame. So why hold back if you HAD to get home.
Does that make any more sense?
Yeah, but CVs are made to "float" at differential end. They are not bolted in at the differential (from what I've seen on many makes/models), so I can't see how they support the suspension. They should move in and out of the differential slightly as the suspension flexes. Otherwise they would pull the axle joints out of socket. At least that's what I think...
Originally Posted by Turd Furguson
The axle pulls the hub inward keeping the tire on.
I disagree with this statement on an ifs axle like our trucks have. The axle half-shaft is designed to transmit rotation only. The cv joints are not designed to handle the torsional load of driving the wheel as well as a tensile load of holding the wheel on. The ball joints handle the vertical and horizontal loads. Even in a non-ifs front end, the axle shafts only transmit rotational force. You break one off road, you pull the wheel, pull the shaft out, stuff a rag in the axle to prevent losing all the diff fluid, and limp home.
If I'm wrong I'll eat my hat, but as a mechanical engineer I believe it would be a dumb way to design an axle to rely on the half shaft to do anything but drive the wheel.
CJ
Just to give you guys an update. I've torn the truck apart and you CAN drive without the axle. The nut on the end of the axle does not hold anything together, but that is not true for all IFS vehicles. I figured by the wimpy size of the nut that it wasn't designed to hold the wheels or hubs or anything else one. All that nut on our trucks does is prevent the axle from popping out of the splines if the suspension drops. Trucks like the 2002 Ranger 4X4 have huge axle nuts... way bigger than the ones on the F-150 and they do in fact hold the bearing together so if you drove one of those w/o the axle installed the wheels would fall off.
Like I said... tried and tested the wheels won't fall off a 2004+ F-150 w/o a front axle installed.
It may have worked for a 2004 f150, but driving a 2000 4x4 f150 without a CV axle will destroy the hub. I found out the hard way today.
My CV boot is torn and needs to be rebuilt. I was already working on my truck putting a suspension lift on, so I decided to take the CV axle out, and continue putting the truck together. I thought that the CV axle doesn't support any weight of the vehicle so there should be no problem driving with out it. I drove a maximum of 1/4 mile and heard some grinding noise. I stopped to see what it was, and the hub was coming apart. Live and learn.
