P0340 cam sensor error after timng cover re seal
I am getting a cam sensor error p0340 after just resealing my timing cover.. When both sensors are plugged in the truck stumbles horribly, and will barely run at low rpms.. when I unplug them the motor runs fine, but throws a p0340and a p0345 I tried swapping them out on a friends truck and same thing.. I checked continuity from the plug wires back to the computer, and the wiring is good... I can't seem to figure this one out... anyone have any sugestions???
This is a 2004 f150 3v 5.4
i am dumb
ok figured it out... the crank sensor wheel was installed backwards... nothing like doing it twice.... the cam code had nothing to do with the cam, it was the crank sensor the whole time... let ths be a lesson, just because you get a code for a specific problem... look beyond...
