My last Dealer Oil Change....WOW
Old Jun 21, 2007 | 10:30 AM
baja150's Avatar
Oh and I bought mine at Auto Zone for like $9... I think Murray's has them too.
Sorry I don't remember the thread of the drain plug.
Old Jun 21, 2007 | 10:31 AM
baja150's Avatar
Originally Posted by anaheim
Is it the angle of the pic, or is the actual opening for that valve that small?
You have to remember that you only have the diameter of the threads to start with, so it can't really be that big.
It doesn't really matter how big the opening where the oil drains out is... it's the size of the channel through the threads that's the bottleneck.
Old Jun 21, 2007 | 10:56 AM
scorpio333's Avatar
For those wondering about the Fumoto valve opening while installed I highly doubt it could happen. You need to push up on a lever and turn it to open the valve. This isn't even easily done by hand once it's one the vehicle.
While I've never heard a bad thing about the Fram Sure Drain, I have a personal dislike for Fram products so the Fumoto goes on all my vehicles.
The drain hole is smaller than the oil pan plug opening but it's nothing major, it doesn't take but a minute more to get the oil drained. Get an N type with the nipple. This will allow you to pop a tiny hose onto the valve and into an empty bottle for easy recycling. No more drain pans and emptying drain pans into bottles for me. Also a good idea is placing a vacuum cap over the nipple to keep any crud from building up on there.
Old Jun 21, 2007 | 12:20 PM
baja150's Avatar
Thanks Scorpio,
I didn't realize you had to 1) push up and 2) turn the lever.
Old Jun 21, 2007 | 06:46 PM
TexasFatboy's Avatar
It's small...only takes a couple more minutes to drain.
Old Jun 21, 2007 | 07:04 PM
moose3776's Avatar
last oil change i decided to take it to dealer where i bought it and let them do it. well after all was said and done the $^$ put 5w30 in it! i thought to myself this guy is supposed to be an ase certified mechanic and he screws up something as simple as an oil change lmao. had it not been on a saturday i would have taken it back and made them change it but i didnt notice til i was almost home and they had already closed.
Old Jun 21, 2007 | 07:37 PM
i.ride.suzuki's Avatar
Big deal?
I put 5w-30 in summer months and 5w-20 in for winter months.
Old Jun 21, 2007 | 08:03 PM
worland's Avatar
After the local Chrysler dealer stripped out the oil pan on my wife's Grand Cherokee (about 1999), I put Fumoto's on all my vehicles. Never had one open up or break off while 4-wheeling. If you're worried about it opening up, you can put a c-clip on it to hold the lever down (the directions for installing the valve tell you what kind of clip to get). I typically put a bit of red or black RTV on the threads when I install them. On the down side. I have had idiots at oil change outfits remove the entire valve instead of just opening it.
Old Jun 21, 2007 | 08:07 PM
moose3776's Avatar
Originally Posted by i.ride.suzuki
Big deal?
its a big deal because manufactures are gettting so **** about maintenance records in order to perform warranty work and 5w20 is what FORD recomends youd think a FORD service dept would get it right
Old Jun 21, 2007 | 09:15 PM
Operation:F-150's Avatar
The drain plugs from Ford are designed to go out instead of the actual oil pan, i would much rather change a 9 dollar plug every once in a while then replace the oil pan wouldn't you?
Old Jun 21, 2007 | 10:13 PM
yoheidiho's Avatar
X2
Old Jun 22, 2007 | 12:03 PM
jbziggy's Avatar
I had the Fram sure drain on my truck for about 8 months, but I had all kinds of issues with it leaking oil. Not a ton, but enough to leave spots in the driveway and parking spots. I had this same issue when I had the Sure Drain on my wife's car. I would not recommend it at all.
Old Jun 23, 2007 | 10:34 AM
last5oh_302's Avatar
I think I'll just stick with the conventional drain plug supplied with the truck. It may save you a lil bit of time using one of these quick release valves but you have to remove the filter as well which also creates a mess so you must use a drain pan to catch the drippings regardless of if you don't use the drain pan to drain the oil. Any way you shake it, you're still emptying oil out of a drain pan so why not just remove the regular plug and let it drain normally.
Old Jun 24, 2007 | 01:12 AM
Tical84's Avatar
Slightly off topic but I found a wrench in my engine bay ontop of the air filter after getting my oil changed at the dealership one time. I had no reason to open my hood so I had driven for about 2000km with it in there until I went to install my e-fans.
Old Jun 24, 2007 | 09:53 PM
tg150's Avatar
Originally Posted by dennisfranz
I am putting one of these on mine n the next oil change:
Fumoto Valve
I have one on my truck and it works awsome..No tools..speeds up my oil changes and the hands stay nice and clean..i love it
