Resume botton on cruise control
What does this button actually do. I think mine is broken. Nothing happens when I press it. Thanks
^^Right^^ let's say for instance, you are traveling at 65mph on cruise, if you hit the brakes on cruise it automatically turns off. However if you press the on button and then resume, it will take you back to 65mph from whatever speed you are currently at. Hope that clears it up.
I don't like the fact that we have to hit the brake to turn cruise off and maintain the resume feature. I think there should be another button of they should reprogram the off button to maintain resume.
Originally Posted by Eastrick
Now that I think about it, maybe it's the "set" button that does that...
Originally Posted by FX4_Guy
I believe the set button should give you a +1mph. While the Cancel button should give you a -1mph. This happens only if you tap it and do not hold it down.
The set button gives you a +1mph.
