Injector Cleaners....
Old Jun 9, 2007 | 09:56 AM
Got two questions...
1. Should I add a fuel system cleaner to my truck every 5k? Something along the lines of STP Complete Fuel System Cleaner... Along with a bottle of fuel injector cleaner?
2. When should I add some of that dry gas into the tank?
Right now my truck is running fine... but I just want to make sure it stays running well. Currently I am getting 20 mpg with a total weight of aprox. 5500 lbs.
Old Jun 9, 2007 | 09:58 AM
FX41's Avatar
i add a can of BG44K to a fill-up about twice a year to keep everything working well....haven't had any probs
Old Jun 9, 2007 | 12:15 PM
Grubrunner's Avatar
I've always been [strongly] advised against adding any type of fuel additive cleaner for the injection system.
I've also heard - first hand - of warranty's being void because of this.
Thumbs down from me.
Old Jun 9, 2007 | 02:31 PM
Tbird69's Avatar
X2, in my opinion it's all snake oil. There's no way putting 1 or 2 bottles of cleaner into 20 or 30 gallons of fuel will do anything. The only way to properly clean the injectors is to use a good grade of fuel and have them professionally cleaned as part of regular maintenance. When the dealer/shop of choice cleans them they run the engine on just the cleaner. This removes the deposits almost completely. Something no fuel additive will ever do.
Old Jun 9, 2007 | 03:11 PM
Quintin's Avatar
1. No.
2. No.
Fuels nowadays have all the cleaners in them you need. If/when you ever do need the injectors cleaned, it takes something a lot more aggressive than any cures in a can that's dumped in the tank.
Just replace your fuel filter every 30K miles or so, and you'll be fine as frog's hair.
Old Jun 9, 2007 | 03:15 PM
Just buy good gas. I use Shell and haven't had any issues. 38,XXX miles so far.
Old Jun 9, 2007 | 05:09 PM
Grubrunner's Avatar
I only use Shell.
Stay well away from BP... the biggest piece of crap!
Old Jun 9, 2007 | 05:37 PM
Also, I was talking to a guy that works on engines... he told me that Kerosene will effectively clean out an engine. Is this true?
What I was thinking of doing was running about 5 or 6 bottles of that stuff at less than a 1/8 of a tank... when the low fuel light is on. That would be a huge concentration.
Old Jun 9, 2007 | 05:49 PM
Quintin's Avatar
Kerosene is a solvent similar to gasoline and will cut through grease and sludge. I don't advocate running it in your engine or in your fuel system though.
Gasolines have all the cleaners you really need nowadays. Just replace your fuel filter every 30K miles or so and don't buy fuel from shady outfits out of 55 gallon drums in someone's barn, and you'll be fine. No injector cleaners or any of that junk needed.
But, if/when you really do need your injectors and fuel system in general cleaned, I'd recommend a Motorvac service. This uses pressurized cleaner that's almost like a soapy water to run the engine and blow all the crap out of the injectors and combustion chambers. It's the only fuel system service I believe in, the only one I've ever seen really drastic before and after results with.
Old Jun 10, 2007 | 12:53 AM
mkinttrim's Avatar
I only use Shell.
Thats funny, BP makes motorcraft oil!
Old Jun 10, 2007 | 01:41 AM
jgonza5's Avatar
I thought Conoco Phillips makes it.
http://theoildrop.server101.com/foru...rue#Post766645
My fuel cap recommends BP Fuels.
Old Jun 10, 2007 | 02:37 AM
Grubrunner's Avatar
I don't use Motorcraft oil either...
Old Jun 11, 2007 | 02:33 PM
Adam06FX4's Avatar
Registered User
shell makes motorcrafts oil. at least they do in Canada not sure about you guys tho
Old Jun 11, 2007 | 02:44 PM
sysman_rick's Avatar
Post
I use Techron fuel system/injector cleaner after every oil change. This is the same stuff,albeit not as agressive as the Techron formulation in gas.
Old Jun 13, 2007 | 01:46 AM
Thanks for all your input. I used it in my previous vehicle, and it made a slight improvement, especially in gas mileage. I threw a new gas filter, did an oil change, cleaned the k&n, and some other minor work, and I got a 3 mpg addition along with using a fuel injector cleaner after doing this.
